Hoe do you get a pump to work if it is just vibrating?
I have a lil hoe tiller and I need a new fuel line that goes into the tank. Where can I find one.
You could try lowes or home depot...however when I work on law equipment such as the hoe tiller or weedwackers, I use tubing for fish tank pumps...you can purchase at supermarket or pet store in like 5-10ft lengths and you can cut it to the size you need. Only cost a few bucks and works like a charm. It is the clear silicone tubing...also just an FYI if your pull started cord ever breaks, you can use parachute cord sold at any sporting good store that replaces the pull starter rope and will never snap again.
Sep 05, 2016 | Garden
I HAVE A 2004 AZTEK AND HAVE VIBRATION WHEN PRESSING GAS PEDAL. WHAT CAUSES THIS?
you don't say where the noise is. that is important to give a clue where the issue is. when stopping on the brakes 3 things happen. you press the pedal and the abs pump starts pumping fluid. the second is the brake capilers start pushing on the rotors to slow the car. the rotors are attached to the wheels and that stops the car. so if the rotors are warped you will feel a vibration in the steering wheel when stepping on the brakes. if its your foot feeling the pump working that is normal for abs pumping. you should feel it and holding the pedal will keep it working and stop you from skidding if everything is working correctly
Mar 10, 2015 | 2004 Pontiac Aztek
Tractor troubleshooting
look for stuck check valve at pto bang it with a dead blow hammer to unstick try that
Aug 27, 2014 | Garden
I NEED ELECTRICAL WIRING DIAGRAM FOR C 180
have you checked the fuel pump relay in the boot lift the carpet up where the spair tyer goes ther is a big green relay i think it green thats the one that runs the fuel pump check this first if thats ok it will be the fuel pump itself there about 28 pounds ish on ebay for new pump hoe this helps ivan
Nov 20, 2013 | 1994 Mercedes-Benz C-Class
Kenmore, model 796.4031, water draining out of opening in back of washer onto floor during spin cycle, this hole is not on the picture in the manual!
Seven water should not be coming out of anything but the drain hose-open it up and look for loose hoes or connection which would leak because of the vibration during the spin cycle-cheers Denny
Oct 18, 2013 | Whirlpool Washing Machines
I ask a question yesterday about a flotec 1 hp pump. How do I know if I need to rebuild the pump or if my well has got to low on water?
how deep is the well can you hear the pump working.or are you able to pull the pump up to inspect it.or can you place ahose down the well to be sure that water is down there,some pumps have a pressure sensor so when theres no water it switches of so as it does not opperate dry,because this will damage the seals in the pump,hoe this helps.
Nov 13, 2012 | Flotec Corrosion Resistant Shallow Well...
All hidraulics funtions are dead, no hydraulic power in machine.
first thing I would do is test the pump itself even if no wear is found you could have a GPM loss.
So you need to do a flow test on it to find otu how much the loss is and check it to the specs of that hydrolic pump first.
May 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Radio not working in 05 Saturn Ion level 3
if the radio cant find a station when you push seek then this is an antena problen it may have simply pulled out the back of the radio do to vibration of the vehicle. this almost sounds impossible but it happens if this is not the case then you need to invest in a new radio
Jan 14, 2010 | 2005 Saturn ION
I am getting a lot of vibration from my pump
there is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Jun 20, 2009 | Little Giant 2-MDQX-SC Inline Pump
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
