Question about Nike Watches
How to change date on my Nike watch?
I've lost my instruction manual for my Nike Ron Analog watch and can't remember how to change the date.
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
How do I change the date on an analog watch , its an idiglo womens watch. Oceanave@pacbell.net
For all those who lost their Timex instruction manuals. Copy this link in to your browser and download manual for any Timex watch: http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 22, 2010 | Timex 27191 Wristwatch
How to change the time display
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Mar 31, 2010 | Nike Triax CV10 Wrist Watch
How to use the function buttons on Nike WC0061 watch
very cool watch, but very different programming...
http://www.nike.com/timing/extranet/product/imarastrive/imara_strive_manual_eng.pdf
will take you to a 2-page manual, better than the original!
i
Jun 05, 2009 | Nike Wc0061 040 Imara Strive Watch
Nike heart rate monitor triax c5
I was able to view the instructions here: (no title)
http://www.klokker24.no/ressurser/1183.pdf
Nov 17, 2008 | Nike Triax C5 Wrist Watch
Luminox Marine 1590- need instruction manual to help setting date and time
This model is like any other analog watch, only difference is the screw-down crown...turn counter-clockwise until crown pops up...pull out 2 clicks and set time...push in 1 click to set the date, then into case completely...remember to screw down watch back into case...good luck :)
Jan 06, 2008 | Luminox Marine 1590 Wrist Watch
Watches Logo
102 people viewed this question
Top Nike Watches Experts
Jimmy Accardi
Electro Med Services...
Are you a Nike Watch Expert? Answer questions, earn points and help others
