Stapler not working on finisher
I have a Utax CD1030 same model as Triumph Adler DC2130/Kyocera KM3035/Coypstar CS3035 and the stapler has stopped working on the finisher. When trying in sort/finish mode or booklet mode, when you press the staple button it beeps twice in quick succession and says these functions cannot be combined. I would be very grateful if someone can help me - have checked the finisher peg/hole and checked for broken staples etc. Thank you.
  • 2072 Answers
SOURCE: AS 300 electric stapler--pulled out
What has most likely happened is part of a staple is stuck in the front portion of the stapler where it forms the staple and presses it into the stapler.
You would most likely have to remove the stapler, and remove the binding staple from the stapler head.
Posted on Sep 28, 2008
  • 40 Answers
SOURCE: Swingline Stapler Staples Only After You Open It Up....
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Posted on Mar 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
goalie39
  • 469 Answers
SOURCE: stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Posted on Apr 30, 2009
  • 132 Answers
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
Posted on Jun 27, 2009
Can I use Kyocera toner for utax Copy machine?
take the cartridge along to a ink refiller shop and ask them as they have a good knowledge of product inchangeability
Aug 12, 2016 | Kyocera Office Equipment & Supplies
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
Our Canon NP6035 copier won't staple. It had a jam in the stapler, which I removed. We installed a new staple cartridge. The stapler makes indentions in the paper, but it won't advance any staples.
Do you have a 10 or 20 bin finisher? I'm guessing you have a 10 bin. Did you install the stapler cartridge in correctly? There is a small black plastic gear that cracks and the stapler will not work. The two way's to solve the problem is to replace the gear or the stapler unit. Both may be had to find. Good Luck
Aug 24, 2010 | Canon NP 6035 Copier
Looking for the part # for a stapler unit for a canon 2020
I know only for U1/U2 finisher, and the part # for stapler unit is 4G3-0480-000
Send me mail for parts catalog on emma.servis@gmail.com
Jul 26, 2010 | Canon ImageRunner 2025I Black and White...
The problem in canon 6050
this error from sorter/stapler unit if this problem is repeated
disconnect the sorter and use copy tray,sorter must be serviced
E530
Main Cause The alignment plate home position sensor (PI6) is faulty. The alignment
motor (M3) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The alignment plate does not leave home position when the alignment
motor has been driven for 2 secs.
0002 The alignment plate does not return to home position when the
alignment motor has been driven for 2 secs.
E531
Main Cause The stapler home position detecting switch (MS7) is faulty. The stapler motor
(M6) is faulty. The finisher controller PCB is faulty.
Mode of
Detection
0001 The stapler does not leave home position when the stapler motor
has been driven for 0.5 sec.
0002 The stapler does not return to home position when the stapler motor
Jun 06, 2009 | Canon NP 6050 Copier
Serice code 792
E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E792 Sorter stapler error
Mar 20, 2009 | Office Equipment & Supplies
E532-0001
An E532 happens when the stapler unit either does not move from front to rear, or rear to front, or hangs up and stops part of the way. A broken stop gate can get in the way of a stapler and keep it from moving. Usually the two inside gates are the problem. The bottom spring may have fallen off when the plastic tab on the bottom of the gate (which holds the spring) breaks off. Or the parts of the gates that come in contact with the white rollers on the stapler assembly become dry and need to be greased to allow the stapler to slide past them. Also check the wiring harness that runs from under the stapler, through an opening and then connects to the stapler itself. Wires have been known to break internally at the wire-tys and cause erratic E532s. Check each wire with a meter for continuity. Hope this helps a little.
Jun 06, 2008 | Office Equipment & Supplies
Triumph-Adler 4035 Firmware
latest firmware for FS-3900DN:
system: 2F9_3000010.004 checksum:5204 version:010.004
engine: S2F9_1000011001 checksum:f7bf version: 011.001
I don't think the problem is in the firmware ...
May 02, 2008 | Kyocera FS-3900DN Laser Printer
Staple function is grayed out - how do you turn it on.
You do n ot need to enter the Service Tech code to ajust finishers. In fact that code should rarely be entered.
Is the option available while copying?
If it in the driver, select the greyed out option and let the driver inform you of the problem/setting.
Has the finisher been identified in the "instaled options" tab of the driver?
Normally, the driver or panel will indicate what the conflict is if any. If all these have been set correctly, contact whomever installed this finisher and have them do it properly.
Apr 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
64 people viewed this question
k24674
jasbo
jasbo
