Question about Vizio Televison & Video
Vizio vp422 hdtv10a picture is fuzzy used to clear up for couple mins on an off but now it flickers fuzzy
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
budmrtn
  • 11361 Answers
SOURCE: after 3 min it turn off wait 1 min it come back on
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 23, 2010
ripleymojica
  • 643 Answers
SOURCE: vizio vx42L HDTV10A screen flickering,
make sure all cables are seated all the way in. unplug set for a couple hours.
Posted on Mar 22, 2011
walesarumi
  • 6993 Answers
SOURCE: We have a VIZIO VP422
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 31, 2011
gopakumarg43
  • 75599 Answers
SOURCE: vizio vx32l hdtv10a no picture
If audio is OK, the problem is with its back-light. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis.
Posted on Jul 04, 2014
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
NNeed parental unlock code for vp422 hdtv10A vizio
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 12, 2014 | Televison & Video
Flickering vizio
You may use 85 degree capacitors, but the life time will be short.
You may find the right capacitors from {Digi key} company.
Feb 10, 2018 | Vizio VX42L 42 in. LCD TV
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Vizio vx42L HDTV10A screen flickering, all the the time.what is wrong with it.
Mar 22, 2011 | Vizio VX42L 42 in. LCD TV
Vizio VA 26 L HDTV10A black screen after on for 3 seconds. Replaced power supply and Mainboard.
There remains only the fluorescent back light tube(s) or the inverter that supplies high voltage for it (them). If you had no warning flickering, I would look for the inverter board.
Dec 01, 2010 | Vizio VA26L 26 in. LCD HDTV
My Vizio 42in. is really fuzzy
If the picture is clear when using a DVD and remains "fuzzy" only with cable, then either the cable is bad or the up-conmvert from standard def to Hidef is creating the "fuzz". Depending upon the method used by the set to perform the "up-convert", the noise you are seeing may be normal.
Dan
Jan 27, 2009 | Vizio L37 Television
Televison & Video Logo
48 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
