Question about Maytag Dryers
I have a maytag dryer LDE8424ACE. When drying the clothes it leaves black smudges or lines on the clothes.i saw some felt sticking out and I pushed it in, but it still happens. Do I need a new dryer?
  • Maytag Master
  • 473 Answers
The felt seal is part of the drum slide/glide system. If you found part of it sticking out that means somewhere there is a spot where the seal is not glued on properly. Usually that creates a gap that clothes can get stuck in and sometimes ripped. It is probably repairable but depending on the age of your dryer you might want to put that money towards a new one. My guess on the repair cost around $150 depending on service pricing in your area.
Posted on Apr 14, 2015
Maytag Neptune Dryer Not Drying Well, Leaves Brown Marks on Clothing. Seems like there may be multiple problems. Suggestions?
Sounds to me like an air-flow problem. Poor air-flow means dryer gets hot and scorches clothes but there is nowhere for the wet air to go, so it doesn't dry well. Check for lint-clogged ducting from the back of the dryer to the outside (or at least check both ends of the duct). Also check for a collapsed or clogged flexible tube that goes from the dryer to the duct work.
An over-heated dryer could also have warped the (usually) plastic lint filter.
Jan 07, 2015 | Maytag Dryers
Black marks clothes
black marks on cloths usually occurs on older dryer when the felt liner that supports the drum, wears out or is torn, leaving a gap for cloths to get pulled into and between the drum-and drum support.
The replacement part (is not felt anylonger) but made of teflon and has self-sticking backing that goes on the front support after removing the old felt and glue. While you at it, order a new belt, that is most likely been slipping when the closes get jamed between the drum and support. Look up your model number on selectapart.com They aslo have tutorials so you can see how to install these items
Sep 09, 2014 | GE Dryers
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Dryer squeeking while tumbling & leaves black smudge on clothes
it sounds like a drum support roller is going bad or the belt idler pulley. i think maytag has a kick panel on the bottom that can be removed. look inside with a flashlight and you may be able to see something. if not, you may have to take the drum out to get a really good look. make a note and study how the drive belt serpentines around the motor, pulley, and drum so you can get it back together.
Oct 20, 2009 | Maytag Dryers
White clothes have black streaks after drying.
You will have to have the dryer drum felts replaced. It requires removing the drum from the dryer so you may want to have a technician do this because removing the belt can be tricky.
Jan 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer is making a scratchy, grinding sound when turning.
some where there's somthing of the drum draging metal to metal.could be the drum glides are worn or the felt seal.you need to remove the front and pull the drum and inspect.unplug unit before tring.if need more help you can email. God bless ,tom ps the stains are the metal shavings ground to a pulp
Jan 10, 2009 | Maytag Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Brown smudges on clothes
Take a look and see if the drum near the door moves up vertically. It shouldn't move more than 3/16ths of an inch. If it does, replace the upper felt seal/plastic slide. The upper seal that supports the front of the drum on the front of the dryer is worn out to the point that clothes can get stuck in the gap between the drum and the front of the machine. This leaves brown wedge marks on clothes. While it's apart, replace the lower felt seal as well.
Apr 20, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Dryers Logo
79 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
