Question about Panasonic CF19 C2D/1.06 10.4TCH 1GB-80GB WLS BT W Laptops PC Notebook
How to access cf19 without password
As it turns on this comes up ''enter password''i would like to knw if i could replace the os much easier
  • NOEL
    NOEL Apr 14, 2015
    Hi javaughn , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Emachine windows 7, i forgot my windows password and have no disc?
There are two ways to do it. One is free, but takes a little care to pull it off. The other is easier but costs $20.00 for a piece of software. Your choice. Here is the link to the two procedures. Choose the one you want to try.
How to reset Windows 7 password without reset disk
Nov 20, 2015 | E-Machines eMachines Desktop PC
Can't remember password and it won't let me change it
You cannot change the password without entering the old one. And you cannot access Windows without it.
Copy all your data off and put a new OS on the drive.
Nov 16, 2013 | Computers & Internet
I turn my acer aspire 5315 on and its asking for me to enter current password but i dont know it and dont know how to get past it what do i do ?
if the password comes up straight away on the laptop and its on a black screen, its a bios password and will be expensive to remove,
only cheap method to try is if the laptop has a internal lithium battery, remove it for a minute then put it back in.
if its a windows password let me know there alot easier to remove.
Jun 17, 2012 | Computers & Internet
Forget password
To change password of an user account, we need to go to User Accounts panel in Control Panel, choose the user account, click on 'Change my password' link, type current password once and new password twice. Too lengthy a process isn't it? Here is handy tip to change Win XP passwords in DOS mode and believe me, it takes less than 5 seconds!! Let me share the hack with you all!
net-user-pwd.gif Steps to change password
  1. Click on 'Start' and then on 'Run...'.
  2. Type 'cmd' (opens up the command prompt).
  3. Now type net user * (do not omit the spaces)
  4. You will get a prompt like .. Type a password for the user:
  5. Type the desired password and press Enter key. Also note that you wont see *****s as you type but don't worry.
  6. You will again get a prompt like .. Retype the password to confirm:
  7. Retype the password and press Enter key. Here too you wont see *****s as you type but don't worry.
Thats it!!! Oh no .. wait .. Did it cost you more than 5 secs? OK Try this ..
Another Solution
Computer passwords are like locks on doors - they keep honest people honest. If someone wishes to gain access to your laptop or computer, a simple login password will not stop them. Most computer users do not realize how simple it is to access the login password for a computer, and end up leaving vulnerable data on their computer, unencrypted and easy to access.
Are you curious how easy it is for someone to gain access to your computer? If so, read on to see the technique one might use to figure out your computer password.
Windows
Windows is still the most popular operating system, and the method used to discover the login password is the easiest. The program used is called Ophcrack, and it is free. Ophcrack is based on Slackware, and uses rainbow tables to solve passwords up to 14 characters in length. The time required to solve a password? Generally 10 seconds. The expertise needed? None.
3237188885_1527db4c72_m.jpgSimply download the Ophcrack ISO and burn it to a CD (or load it onto a USB drive via UNetbootin). Insert the CD into a machine you would like to gain access to, then press and hold the power button until the computer shuts down. Turn the computer back on and enter BIOS at startup. Change the boot sequence to CD before HDD, then save and exit.
The computer will restart and Ophcrack will be loaded. Sit back and watch as it does all the work for your. Write down the password it gives you, remove the disc, restart the computer, and log in as if it were you own machine.
Mac
The second most popular operating system, OS X is no safer when it comes to password cracking then Windows.
The easiest method would be to use Ophcrack on this, also, as it works with Mac and Linux in addition to Windows. However, there are other methods that can be used, as demonstrated below.
If the Mac runs OS X 10.4, then you only need the installation CD. Insert it into the computer, reboot. When it starts up, select UTILITIES > RESET PASSWORD. Choose a new password and then use that to log in.
If the Mac runs OS X 10.5, restart the computer and press COMMAND + S. When at the prompt, type:
fsck -fy
mount -uw /
launchctl load /System/Library/LaunchDaemons/com.apple.DirectoryServices.plist
dscl . -passwd /Users/UserName newpassword
That's it. Now that the password is reset, you can login.
Linux
Finally, there is Linux, an operating system quickly gaining popularity in mainstream, but not so common you're likely to come across it. Though Mac and Linux are both based on Unix, it is easier to change the password in Linux than it is OS X.
To change the password, turn on the computer and press the ESC key when GRUB appears. Scroll down and highlight 'Recovery Mode' and press the 'B' key; this will cause you to enter 'Single User Mode'.
You're now at the prompt, and logged in as 'root' by default. Type 'passwd' and then choose a new password. This will change the root password to whatever you enter. If you're interested in only gaining access to a single account on the system, however, then type 'passwd username' replacing 'username' with the login name for the account you would like to alter the password for.
Conclusion
There you have it - that is how simple it is for someone to hack your password. It requires no technical skills, no laborious tasks, only simple words or programs. The moral of the story? Encrypt your data to keep it safe. Don't use only a password, but actually encryption, such as Blowfish or AES-128. There are a number of programs that can do this - TrueCrypt for Windows, or the native encryption found on Ubuntu, creating a disk image in Mac, etc.
Aug 09, 2011 | Computers & Internet
I have an Acer Aspire 5517 laptop. As soon as I turn my computer on a box comes up saying "hard disk security". I can press the Enter key and a different box comes up saying "Enter password...
It's requesting a password that was entered to access the operating system. If you don't know or remember the password you will have to wipe out drive and reload the OS.
Jan 05, 2011 | Computers & Internet
Yahoo.comHow to uninstall deep freeze 6 software from PC
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password. 1. Boot yr PC from the CD with windows XP, if u have Windows XP OS 2. Now enter R to repair after booting. 3. Let it continue until finish 4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
Aug 25, 2010 | Computers & Internet
I dont have the useername or password to the mac
Not many things you can do with a situation like that, you are probly looking at formating the hard drive and reinstalling everything. OR Make life easier ask your friend to come over enter his user name and password and then disable them. :)
Nov 09, 2009 | Apple Mac OS X 10.4
Lost log-in password
what is password? for windows? for BIOS? for what?....
you use eeePC with Linux OS or Microsoft Windows OS? For Linux, follow my instruction for recovery your OS. Press F9, after you turn ON your netbook. And follow that instruction. Or you can use recovery DVD (include your netbook), after you plug in external DVD-ROM and make it boot priority for first is DVD-ROM (enter your BIOS first).
Sep 21, 2009 | ASUS Eee PC 701 Notebook
No password to enter computer
When the login screen comes up and asks for the username and password.
Username - Administraion
there should be no password for that account.
Once into the system go to the control panel and then to user accounts and change what you desire.
XP home hold F8 untill you get to the boot mode and choose Safe Mode once in to the system go to control panel and user accounts and do the same as above.
If this doesnt work please respond with OS.
Dec 05, 2007 | Acer Aspire 5100 Notebook
Panasonic CF19 C2D/1.06 10.4TCH 1GB-80GB WLS BT W Laptops  PC Notebook Logo
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
