Question about Tecumseh Heavy Machinery
Need manual; specifically how to get the pulley off of the drive shaft of the Tecumseh 10 hp motor
3 Suggested Answers
harlan301
  • 205 Answers
SOURCE: need to replace the recoil rope and handle on a
take the 4 bolt out of the starter housing, lay on table take the old rope out. turn the center rope pulley counter clock 6 to 7 full rotation's so the center pulley hole lines up with out housing hole(steck a screw drive throw to hold pulley in places). feed the rope from outer throw the center tie off. let the pulley dr ow the rope in. pull the rope out a Little tie off to handle
Posted on Oct 14, 2009
  • 640 Answers
SOURCE: need new air filter for
You can look up the air filter with the model number and order it over the internet from a website such as partstree.com, but there are others. Or, you can get the model number and go to your local small engine repair and parts shop. Mine had it on the shelf. If your chipper/shredder is like my 8 HP Craftsman with a Tecumseh engine, then as you are looking at the engine, look on the left side of the shroud or cover and way down low on the curved portion is a label with the model number on it.
I hope this is helpful for you.
Posted on Aug 24, 2011
What is sparkplug gap on 8 horse tecumseh snow blower
Clif - I have two items in my garage with Tecumseh engines on them in that HP range and they both specify .030 spark plug gap in the instruction manual.
Dec 03, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
I have a 10 hs tecumseh motor on a riding mower i need an explode view of carb and linkage when start-up engine it goes wide open
Hi and welcome to FixYa, I am Kelly. I understand you have a 10 HP Tecumseh engine. There are service manuals available on line for your engine but without your engine model number it is difficult to pass you the correct one: Here is the link for the service manuals:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals
Somewhere in the list is your manual.
This is my best guess without your engine model number:
http://www.mymowerparts.com/pdf/Tecumseh_Service_and_Repair_Manuals/TECUMSEH_SERVICE%20_REPAIR_MANUAL_OHH50-65_OHHSK50-130_OHV11-OHV17_OVM120_OVRM40-675_OVRM120_OVXLC120_OVXL120_OVXL125_695244A.pdf
^-Make sure you read about Adjustments in section 1 also.
Running wide open causes:
1. Broken throttle control plate spring
2. Governor spring problem
3. Internal Governor flyweight has departed the governor gear.
4. Throttle plate (butterfly) attached to the throttle shaft in the carb throat has come off the throttle shaft.
5. Broken / missing linkage
6. Someone loosened the governor shaft bolt at the base of the governor arm and allowed the governor to get out of adjstment.
Thanks for choosing FixYa,
Kelly
Aug 12, 2011 | Tecumseh Garden
I have a 10 hp Tecumseh Gold Series Snow Bolwer with 6 forward speeds and 2 reverse and I'm trying to find a owners manual for it, thanks.
If you locate the model number of your motor you should be able to download an Operator's Manual for the motor form this site:
http://www.tecumsehpower.com/
Is this an actual Tecumseh brand snow blower or another brand with a Tecumseh motor installed?
Jan 28, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
Need to replace the recoil rope and handle on a tecumseh hm80 155481 p 8hp horazontal shaft motor. never done one before so any suggestions would be great
Oct 08, 2009 | Yard Machines Heavy Machinery
Wiring diagram for 10 hp tecumseh motor.
no worries go to searsparts.com type in your model # and follow the prompts you can then print it out for free ?
Aug 27, 2009 | Garden
Tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
Mar 23, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Switch missing on 10 hp Tecumseh engine that is installed on a
First I have never owned a Tecumseh Tiller. How that got attached to me I don't know. I do have a 10 Hp Tecumseh Engine that I wish to check out if it is good or not before I buy a switch. It has a Brown wire that goes to the low oil shut down sender. It also has a green wire and a black wire. All I need to know is which wires do I need to put together so I can check if the engine is firing or not.
Feb 19, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Heavy Machinery Logo
285 people viewed this question
Top Tecumseh Heavy Machinery Experts
methjd
Bilral
Level 1 Expert
szanghi
Are you a Tecumseh Heavy Machinery Expert? Answer questions, earn points and help others
