A weak vinegar/water solution should remove calcium deposits. I either used purified water or I add a tiny bit of vinegar to the water when I use the humidifier to help prevent calcium deposits from forming.
The mix of vinegar to water is up to you, but as a guideline, if you're smelling a strong odor of vinegar, then it is likely that your solution is too strong - try adding some water to it. Rinse with clear water afterwards.
