Question about Blodgett Ovens
When I turn on my 2001 blodgett 2136 E/AB it flashes SP MTR, the belt wont run, and there is a loud buzz. What's wrong?
I haven't run these in a while. I turned them on and they appeared to run fine and when i went to shut them off the top oven acted like it went into a seizure and started beeping. I had to disconnect from wall and cool.. then I restarted and the message board said SP MTR and the belt wouldn't run and it just buzzed loudly. Can you help identify what this is and where to get a part if needed?
  • 1,252 Answers
Http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/BL_MT2136_sm.pdf
this web site shows your manual and indicates that the issue is the motor needs attention. I would think that the motor has failed mechanically and is "Locked Up." The buzzing is the motor trying to run but can not as it does not move. The SP MTR indicates motor speed issue.
Posted on Aug 19, 2017
SOURCE: a loud buzzing when Lincoln 1456 impinger pizza gas oven fires.
this sounds like the gas solenoid valve you may need to change the coil on the solenoid valve
Posted on Aug 21, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a Whirlpool double
Strange, I would have thought it was the thermostat (temp sensor as you call it).... It may be the actual electric portion of the control panel itself malfunctioning... There is not much behind the control panel that could buzz aside from the control panel itself.
Check out the part I believe you need here, this site is really handy for this type of thing:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5132068&diagram_id=930365#d930365
It is number 6 on that list there... the CNTRL-ELEC they call it. You sound very capable so I would say try and replace that, I bet it'll fix it right up!
Tim
Posted on Oct 01, 2010
barkencoa
  • 3463 Answers
SOURCE: My AEG competence oven is
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Posted on Dec 12, 2010
taran_2005
  • 10515 Answers
SOURCE: We have a Renaissance Wall
This is a common problem on this model and discussed many times by us here and in different forums.
CO1 means you have a shorted touch pad and need to replace it.
In the beginning, you might be able to reset the code by pressing Cancel or by disconnecting the power supply for few minutes. However, that is an indication of touch pad ( or shorted key failure ).
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 19, 2011
SOURCE: when I turn on my
Mine does the same thing. Not sure why? Let me know if you find out.
Posted on Aug 26, 2011
BLODGETT MOTEL NUMBER BCX14 OVEN WONT STEAM OR WORK ON COMBO ANY ADVICE ON MATTER
http://www.blodgett.com/wp-content/uploads/BCX14G-serv.pdf
Try this website as it has a service manual for this oven. May help you dial in on the issue.
Jul 10, 2017 | Blodgett Ovens
My blodgett mark v oven wont get above 325 degrees
Maybe you need to adjust the thermostat? Do you have a User's Manual? If it's not the thermostat, and your oven is on warranty, you should call service. If nor on wattantym you should pay one of your preference
Feb 06, 2015 | Blodgett Ovens
Blodgett oven mark v 111 can cool down but not cooking
door switch need to be checked or repalce. you can put 2 wires connect together and turn on see motor is running, if it run that mean switch is bac...good luck.
Jun 05, 2014 | Blodgett Model Mark V Single Electric Oven
Is there such a thing as a descaling unit for a blodgett combi oven model bc14g/ab
These combi ovens are so prone to problems if you do not have descaling filter system hooked to the COLD water supply (the only water that should be fed to this unit) for your generator inlet. The other water hookup is for your condensate drain (condenses steam leaving cook chamber headed down the drain) and it does not need to be filtered but, also needs to be COLD. These decaling units are quite pricey but, a service call to replace the generator (boiler in laymens terms) will cost 3 times as much & the unit will be down for days waiting on parts. Call Blodgett w/ your model # & talk w/ technical service & ask their recomendation. They can be reached @800-331-5842 & follow the prompts. Depending on your water conditions it is still recomended to descale the unit on a regular basis using a QUALITY descaler (not the junk you buy from Sysco or Dollar general) Cleveland descaler is the BEST.
Jul 24, 2009 | Blodgett Combi® BC-142G Stainless Steel...
How to reverse the conveyor belt on a blodgett pizza oven
reverse the wires on the conveyor motor
Apr 20, 2009 | Ovens
Oven will not heat past 300 degrees
300 far. or cels if its celcius its to high they should run at about 260 or the high temp sensor will shut it down how fast is your belt running it should be 6.30 to 7.00
Jan 28, 2009 | Lincoln Conveyor Oven - 1133-000-A
Blodget Oven
did they sell you a broken one?
Jul 05, 2008 | Blodgett DFG-100 Gas Single Oven
Ovens Logo
277 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
