Question about Apple iPad 2
How do I set up a wireless connection? - Apple iPad 2
  • 71 Answers
Hi
Its depend on which ISP(internet service provider) do you have
please let me know clearly what you asking
Thank you
Harsha
X VIRUS LAB
Posted on Apr 14, 2015
A WiFi connection potensWL has popped up on my wifi settings. I do not know what this is but want to delete it. How do i do it? I have a Samsung Galaxy tab 2.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them. To do this, tap on the connection in >Settings >Wireless and networks and ou will be given 3 options, Connect, Forget, Cancel. You need "Forget".
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code.
It is worth remembering that your tablet will always notify you (via Wireless and Network settings) of all wireless networks that are within ita range.
Cheers
Feb 28, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
I cannot get on my wifi it tells me security warning I have played this all day now it tells me this
Greetings... Im not sure what is giving you the security warning message? Is it your INTERNET Wireless gateway or is it the Tablet ?
If u go into the Settings tab..then down to wireless on right side of screen is a scan icon. If u run the scan do u see your wireless connection? IF not u need to have the SSID for ur wireless device. Then make sure u have the correct password and premission to access this device.
Then be sure to make sure the airplane and VPN settings under your wireless settings are correct.
If your trying to connect to wireless while in USB connection to a computer.. sometimes the DEBUG mode can cause errors too.
If this fails try resetting the tablet with the port on back and your wireless device to.
If still have problems repost to this post and ill follow it and see if we can get u fix
Chad Man
Sep 25, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Craig tablet cmp741e
This can be caused by a number of issues most have to do with the router itself and not the tablet. First, let's make sure the router DHCP Server is not frozen so take the following steps:
Step 1: If the router is separate from the Cable or DSL Modem, power down the router/wireless, next power down the cable/dsl modem. Power up the cable/dsl modem wait 60 seconds then power up the router/wireless wait 2 minutes
Step 2: Try to connect to the wireless
Step 3: If you have a modem or wireless router supplied by Comcast, Verizon, AT&T or any major carrier, contact them asking them to walk you through resetting and rebooting and updating the firmware to the router/wireless.
Step 4: After the reset and update try to connect, if it fails move on
Step 5: Log into the wireless/modem - let's change the wireless encryption. Go to the wireless settings, change the wireless settings to WPA Personal and add any pass-phrase. Try to connect using the new pass-phrase.
Step 6: If you still can not connect, as a last resort switch the wirlesss encryption to WPA for testing. Try to connect, if this works contct the vendor and have the modem replaced.
Jun 08, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • May 12, 2013 | Samsung Galaxy Tab Tablet PC
    I can not connect to wifi
    If you have a wireless router and it is connected to the DSLor cable modem then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
    Dec 25, 2011 | Tablets & eReaders
    I cant connect to internet but i installed the necessary driver
    To connect to the Internet you need a few extra things aswell as a network card.
    1. You need to sign up with an Internet service provider.
    2. Connect a LAN cable from your computer to the DSL or cable modem
    3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
    4. Install Internet Explorer if it has not been done.
    5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet. If you have a wireless router and it is connected to the DSLor cable modem then -
    To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
    May 18, 2011 | IBM ThinkPad X41 Tablet PC
    I just got a T301 tablet/ereader. I cannot download books for some reason. Any suggestions. I have no idea what I am doing incorrectly. Thank you
    LETS CHECK YOUR INTERNET CONNECTION FIRST
    Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
    Jan 24, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
    Soon im ganna kill my self or break my hp compaq tc1100 in pieces okay my friend reformated my pc i've lost the recovery cd therefore i downloaded all the drivers for my compaq on hp website but i dont...
    Check to make sure your wireless card is enabled in the BIOS. hit f10 or the toggle switch @ startup. go to Devices in the BIOS and check to make sure both options for your wireless card are turned on. I had this issue with the tc1100 with the 2200bg intel wifi card.
    Jun 10, 2010 | Compaq 348348001PANEL Tablet PC
    Apple iPad 2 Logo
    32 people viewed this question
    Top Apple Tablets & eReaders Experts
    Virgil Wolter
    Level 1 Expert
    Aaron Galvan
    Level 1 Expert
    Yoav Shilon
    Yoav Shilon
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
