Question about PIAA 2002 Chevy Cavalier - All Cavalier models - Xtreme White Bulbs
My abs light is on and the trac sign is also on ...car was just in for repairs and seems to be fine
Abs/trac lights on PT CRUISER 2002
Abs/trac lights on ??? Take it to a qualified repair shop and have diagnostics done . At least have codes checked
Aug 13, 2017 | Cars & Trucks
I have a 1998 chrysler town & country lxi the abs light & trac off lights are on & won't go off & recently my van at times doesn't want to start or it turns over & then cuts off & ...
ABS and Trac off lights on , did you have it checked for DTC'S - diagnostic trouble codes ?
no one seems to know whats wrong ???? Have you had it to a repair shop or a dealer ?
Sep 07, 2017 | 2005 Chrysler Town & Country
2004 Mustang Cobra Trac Off / ABS Light ON
i would check your power steering fluid and look at your hydro booster for any leaks your power steering is what powers the brake system on your car because it does not use vacuum an when my abs light was on an trac was stuck off it was just the fuse so i would check that hope that helped you any
Dec 28, 2009 | 2004 Ford Mustang
ABS, brake, trac control, service engine soon light came.
I'm sorry to say that you will need to see a dealer or repair shop so they scan your ABS for trouble codes first and then find your problem.
Jul 24, 2009 | 2000 Oldsmobile Intrigue
1994 850 wagon trac light and abs light come on while driving
I will bet money that it is the ABS/TRACS module. It is mounted under the master cylinder on the bottom of the ABS unit. These are very, very, very common failures. I have replaced hundreds of them in my career. To answer your other question, the TRACS system uses brakes. For example: in the snow, when the L or R wheel is spinning faster than the opposite, the TRACS will apply brake to the spinning wheel to slow it down to an equal speed. Hope this helps.
Jun 29, 2009 | 1996 Volvo 850
Parking light (repair light) came on with abs, trac off and service engine soon lights. Bearings are fine, but there could be a front caliper problem,
There is a problem with one of your speed sensors, or the ABS module itself. Get it checked out to know for sure what is going on.
Jun 09, 2009 | 2000 Oldsmobile Alero
Low trac light won't go off
1st check the wires to the sensors at the wheels. might of broke or came loose (front wheels)
Jan 04, 2009 | 2003 Oldsmobile Alero
ABS,BRAKE and TRAC light on for a while
some times the sensors on the car receive a power serge
this causes them to overreact don't stress if they are not and everything seem fine it was probable a glitch
my sisters Mazda dose the same thing some times
Dec 27, 2008 | 2004 Chevrolet Cavalier
PIAA 2002 Chevy Cavalier - All Cavalier models - Xtreme White Bulbs Logo
297 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
