Question about Cameras
Why won't my new camera move on from the first screen?
I have changed camera to video mode and pressed OK and then tried to move to the next setting but none of the keys will let me.
    Top Expert:
  • Cameras Master
  • 10,875 Answers
Read your manual that came with your new camera
Posted on Apr 14, 2015
How do I get rid of a flashing message "Display Mode out of range"
Here is an article from Microsoft on this problem. Good Luck !
20x20_grey_minus.pngCause This behavior can occur if the signal from the video adapter exceeds the scan range of the new monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor. uparrow.gifBack to the top ' Give Feedback 20x20_grey_minus.pngResolution To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Jan 24, 2015 | Computers & Internet
How Do I Reset Date/Time on a Stealth Cam STC-U732IRNG?
SET TIME AND DATE:
1. Switch the camera to the ON position.
2. Press the [MENU] button to enter menu settings screen.
3. Press the [UP] or [DN] button until the word PIR blinking.
4. Press the [OK] button to confirm.
5. Press the [UP] or [DN] button to scroll through different setting modes
until the word TIME blinking.
6. Press the [OK] button to choose the Time settings.
7. Press the [UP] or [DN] button to adjust the Minute setting and press [OK]
to confirm and move to the Hour setting.
8. Repeat to set Hour and then press [OK] to confirm and move to Date.
9. Adjust the Month, Day and Year by using [UP] or [DN] button. Each time
you finish an adjustment you must press the [OK] button to confirm and
move to the next field for adjustment.
10.Once done, the word - dEL - will be blinking.
11. Press the [MENU] button to exit and start using.
Nov 16, 2014 | Cameras
I have a Kodak M850 Easy Share hooked up to my television with an mini HDMI cable. The picture shows nicely but I don't know what camera button to use to make a slide show appear on the tv. Can you help?
Starting the slide show
  1. Press the Review button, then press the Menu button.
  2. Move autourg00422004id1197998.jpg to highlight Slide Show [img src="http://resources.kodak.com/support/jpg/en/manuals/GLB_en_urg_00422_images/autourg00422004ID1198002.jpg" alt="">, then press the OK button.
  3. Move autourg00422004id1198023.jpg to highlight your option, then press the OK button.
Mar 18, 2014 | Kodak Cameras
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    Hello.i just bought an LG L1742S-SF monitor and when i connected to the unit it shown the next warning:out of range and a certain frecvency.Can you tell me what would be the problem?Thank you
    Apr 29, 2011 | LG L1742SSF 17 inch Monitor
    How can I use it as a camera? I have it all plugged in and installed but it won't regester as a webcam :/
    Connect camera to PC with USB cable. On camera switch on and press joystick/OK to get menue on screen. Move joystick to get the set-up icon highlighted and press in OK. Use joystick down arrow to move down menue to "USB mode". Use joystick right or left arrow to change setting to PC CAM. Press OK and you should now have camera acting as a webcam.
    Mar 16, 2011 | Fuji FinePix F601 Zoom Digital Camera
    How do you change the Date Time Stamp in the GoPro Hero series of cameras?
    Taken from manual:
    SETTING THE TIME AND DATE
    You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
    removed the time and date settings will be lost:
    Symbol on LCD Screen Function
    When you see "dAt" on the screen, press SHUTTER button to set the
    time and date.
    Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
    Press SHUTTER to advance to next date setting.
    Press POWER/MODE button to toggle from 01 (January) to 12 (December).
    Press POWER/MODE button to toggle from d01 (1st day of month) to d31
    (31st day of month). Press SHUTTER to advance to next date setting.
    Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
    (11 p.m. military time). Press SHUTTER to advance to next date setting.
    Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
    minutes). Press SHUTTER to advance to next date setting.
    1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
    for the settings menu.
    EXITING THE SETTINGS MENU
    When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
    Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
    Every time i try tyo use a specific setting it changes
    Hi!
    Please remove the Battery from the Camera then press and hold the power button for 30 seconds. Next, reinsert the battery pack and turn ON the Camera.
    You may also try resetting the Camera to the original factory settings by follow the steps given below:
    Press Home button on the Camera to display home screen.
    Select Settings with left/right arrow on the control button.
    Next, select the Main Settings 1 then Initialize and OK.
    Performing the above steps will reset the Camera to the original factory settings.
    If the issue persists even after performing all the above steps then service will be required.
    Aug 24, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
    Out of Range message displays when PC boots
    The settings that you have for you tower needs to be changed if you have a old monitor connect that to the tower then right click on your screen go to settings and set it real low once this is done connect the new monitor up and set where you would like it,
    The out of range is just letting you know that the settings thats set the monitor can see
    Mar 12, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
    Noise during video recording
    Turn off Continuous AF (auto focus) to prevent recording camera noise during video capture. When you turn off Continuous AF, you may notice a narrower area of focus or depth of field, especially if you zoomed to a telephoto position before recording. Turn the Mode dial to Video, then press the Menu button. Highlight the Continuous AF menu, then press the OK button. Highlight Off, then press the OK button. (On is the default.) Press the Menu button to turn off the menu screen. This setting remains until you change it, change the Mode dial, or turn off the camera.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Cameras Logo
    32 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
