Question about Conair Cuisinart DTC-975 12-Cup Programmable Thermal Coffeemaker - Black &
Why is the coffee spilling/leaking everywhere during a brew cycle?
This continues to happen. I am not spilling grounds while filling the coffee-maker. Does it just need a clean cycle?
    Top Expert:
  • Conair Master
  • 52,126 Answers
Wrong filter possibly my Bunn does that with non bunn fliters
Posted on Apr 14, 2015
  • Angela Rumohr
    Angela Rumohr Apr 14, 2015
    I don't think that's it. I've had the product for nearly three years, using the same filters without issue until now.
Why does my mr. Coffee decanter leak?
First I'm not a Mr. Coffee tech but I have worked on similar machines.
* Most decanters are made of tempered glass and unless cracked it should not leak.
* Most overflowing pots are caused by over filling brewing tank. This can be caused by re-pouring additional water into the brew tank. (automatic brewers may have a leaking water valve - call your vendor for service)
* Partial brewing (taking coffee from a brewing pot) and then putting in more water.
* Removing the pot BEFORE it stops dripping. It leaves a puddle of coffee on the warmer plate
*Over filling the water tank. Most times the extra water will spill out the back. But some may overflow into the basket area then the warmer plate.
* Follow the MFR brewing instructions for filling.
* All brewers should stop water drips after brewing. If you get a constant drip AFTER brewing then have the brewer checked or replaced. Call your vendor.
Aloha, ukeboy57
Jan 15, 2018 | Mr. Coffee Coffee Makers & Espresso...
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
Brewed coffee leaking into spill tray underneath
HI
You have a stripped thumb screw. It needs to be replaced. It holds the filter screen in.
Dec 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
Leaks while brewing does not drain into pot fast enough
Usually you would need a new filter basket for that, which you can get from the manufacturer. However, I was just recently informed by someone w/ a very similar issue that running vinegar and water through the unit may help that as well. But if that doesn't work, definitely contact the manufacturer about getting a new brew basket (800-726-0190), because I've often found that it's the gasket within the spring mechanism at the bottom that is weakening and pinching shut when it heats up.
Aug 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Coffee not going into carafe
doesnt matter what filters we use this coffee maker is dumping coffee and grounds everywhere
Dec 27, 2007 | KitchenAid KCM511 Coffee Maker
Leaks grounds at removable filter.
You can get entire brew units on E-Bay for 25-50$.
Nov 27, 2007 | Solis Master 5000 Espresso Machine
Conair Cuisinart DTC-975 12-Cup Programmable Thermal Coffeemaker - Black & Logo
215 people viewed this question
Top Conair Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Conair Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
