How can I get a replacement for this broken volume control?
  • 3,320 Answers
You won't find a replacement for this part as these low cost electronics are never manufactured with spares.
You could look on ebay or craigs list for a damaged one to use for parts. eBayeBay
Posted on Apr 15, 2015
    Top Expert:
  • Audio Player... Master
  • 50,314 Answers
Make and model required here
Posted on Apr 14, 2015
The volume control is not working... even when the volme is "off" it is still on
Chances are the resistance element in the volume control has broken. This is COMMON if the control knob gets smashed some way.
A less common thing would be broken solder where the control is soldered to the circuit board. This would be obvious once the board is accessable.
Servicing involves removing the chassis and replacing the potentiometer.
Jan 17, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Yamaha RX-V800 volume control
i would say that the component that controls the sound level (called a potentionmeter) or (varible resistor) is either broken or faulty....you will need to remove the cover and inspect the area around the volume control just to make sure it is not broken or that any wiring has just become dry jointed....if all is good then what i would suggest to do is to find out the value of the pot...normally there around 10-50K then youll need to get a replacement...if this still dosen't fix it or your confident enough to look or fix it yourself i would take it to a local electronics repair shop....remeber to disconnect unit from power before removing cover hope this helps,ben
Jan 09, 2010 | Audio Players & Recorders
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
Broken Volume control
the stereo jackbus is stuck in headphone modus
unscrew remote and open up back part of stereo-connector repar switch and reassemble
Apr 27, 2009 | Creative Labs I-Trigue L3500 Computer...
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Broken volume knob
I located the remote control for the unit and it works fine. As the unit is not the primary amplifier for the home stereo system, I use the remote to control the volume. Thank you for your quick responce, and I will keep you in mind for any future needs.
George Keeler
Dec 31, 2008 | KLH R5100 Receiver
Volume control on unit
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Sep 14, 2008 | Yamaha HTR-5550 Receiver
Ive got a nwz-a818 walkman when I switch it on the volume control comes on and overrides all the other controls
it may be that your volume button has broken on the inside. If this has happened, then it may be that the momentary on switch has been forced down and is pinned down by the broken piece of plastic/metal. If the volume is stuck all the way up/down then I'm probably right. As long as you have a warranty that is still in effect, you can get the device fixed or replaced.
Aug 18, 2008 | Sony Audio Players & Recorders
Razr volume control not working
your volume control switch has a problem tha was not related with your soft ware, that was damaged by presing hard your volume botton. you can change the change the switch under your volume botton or replace the whole flex at the back of LCD of your phone. of you are not famillar with relacing a flex, you better ask for assistance from the cellphone technicians near you. good lack
May 14, 2008 | Motorola Mobility RAZR V3c Cellular Phone
176 people viewed this question
 Grubhead
Grubhead
