Question about Dayton Audio Dayton 4YG31 Horizontal Band Saw
What is the length of the blade - Dayton Audio Dayton 4YG31 Horizontal Band Saw
    Sergeant:
  • 468 Answers
The blade length for your band saw is 119-1/2" .
Posted on May 13, 2015
The length of the oil dip stick blade
Hi Collin:
You've asked a question, but not mentioned the problem.
If the handle brokr off and the blade slid down, the question should be, "How can I get the blade out?.
If that's not the problem, I'm not going to tell, and I'm not going to go and measure the dipstick in my old truck.
Oct 02, 2015 | 1990 Dodge Dakota
What size of blade
The blade length is probably almost 100" , but I suggest you try to calculate the length , try this method Calculate Belt or Band Saw Blade Length VintageMachinery org
Jul 08, 2014 | Saws
Band saw blades
Where are you located? Sawblade.com is an online blades supplier , they custom weld band saw blade to your required length.
Apr 14, 2014 | Saws
Manual for 1.3 hp Craftsman band saw
The blade length of the saw is 70.5" . You can get custom length blades on www.sawblade.com . You may visit sears site to get manual for that saw.
Jul 26, 2013 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
I need to replace the windshield wiper blade
The 1998 Dodge Grand Caravan takes 28" wiper blades on both sides front and a 18" rear wiper. See related links below for more information. Since there are over 22 different wiper arm attachments, do not buy wipers just by length only - be sure to lookup exact wiper blade part numbers by vehicle make, model and year for the brand wiper you decide to purchase. This ensures correct length AND correct attachment.
1998 Dodge Grand Caravan Wiper Blade Size Options w/Correct Lengths & Attachments
1998 Dodge Grand Caravan Wiper Blade Installation Videos (hook front, hook rear)
Sep 09, 2011 | 1998 Dodge Grand Caravan
The blades where replaced but not with Ariens blades there is a 1inch gap when you mow in the middle.Is it he blades or the shafts bent
The one thing you have to make sure is that the blades are the correct length or in the correct positions. This is most likely were your problem lies. I have a 42 inch Sears and the blades are of all equal lengths. When you rotate by hand the blades if allowed look like they would touch but are very close. Good Luck...
Aug 16, 2011 | Ariens 42" Riding Lawn Mower Blade ...
The windshield wiper does not clean the entire windshield. It misses the center. I have replaced the wiper blade. Is there an adjustment for that?
It sounds like you are using the wrong length wiper blades for that vehicle.
Have an auto parts store look up the wiper blades according to the application of your vehicle (the auto part store will tell you the length), and then check to see if the wiper blades that are on your vehicle are actually the same length as what the auto part store said should be on the vehicle.
It is not unusual to find the wrong size wiper blades on those vans. (Having a 20" wiper blade when the application calls for a 22" wiper blade)
May 13, 2010 | 1999 Ford Windstar
I need a bandsaw blade for a Craftman 3 12 ( vint. 1952 ) with a blade number 9-2664
You'll need to find out the length of the blade in inches. If you have an old broken one, you can simply measure it. Then if you search online, you'll find a variety of sources that will weld/braze a custom length blade for you. (link here)
Otherwise, you might find a manual here. that gives the standard length for that machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 25, 2009 | Saws
Band saw ,blade length
The blade length used on the 9422 is 52.75 inches.
Please rate this solution on FixYa!
Apr 17, 2009 | Saws
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Dayton Audio Dayton 4YG31 Horizontal Band Saw Logo
399 people viewed this question
Top Dayton Audio Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dayton Audio Saw Expert? Answer questions, earn points and help others
