Is it possible to replace the drum bearings on an INDESIT IWE81281KECO WASHING MACHINE as im told its a sealed drum and so cant be replaced.
The drum bearings have gone on my machine and I have replaced bearings before but in a really old machine. This machines warranty has ended and it's not insured (yeah I know should have). I thought it would be easy to do like the old washer but I'm told it will be a welded drum and impossible to get in to. Anyone know if that's right? Has my washer had it?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Take drum out uve nothing to lose
Posted on Apr 27, 2015
  • 641 Answers
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
Posted on Aug 16, 2007
BIKER T
  • 909 Answers
SOURCE: suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
  • 183 Answers
SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Posted on Aug 30, 2007
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
Posted on Jun 23, 2008
VtToolMan
  • 704 Answers
SOURCE: im needing to know how to install the replacement
Candie, The tub gasket (door seal) is part number #WH08X10022 with a new substitution part #WH08X10036. However, since each model can be slightly different, depending on the serial number which denotes when it was manufactured, you might want to confirm that the above gasket is the correct one for your particular washer.
I'd suggest you call the folks at Sears Parts Direct at 1-800-252-1698 and give them your complete model number AND serial number before you start in on the repair, so you can be sure you have the correct substitution bellows gasket.
It's a relatively easy repair, all you need to do is remove the spring retaining wire around the outer edge of the bellows gasket, just peel it back at the edge to see it. Now locate the locking loop by going around the rim. Once you find the locking loop, you can remove it using a couple pairs of small needle nose pliers as they make it easier to get off.
Once you've done that, you'll see the locking plate that holds the back side of the bellows gasket onto the outer washer tub. Remove those fasteners and you can get the bellows off and start in on putting the new bellows onto the washer, just reversing the order you used in the removal process.
Here's a line drawing that shows the exploded view of the tub section, with the gasket (item #306). Just take your time removing the old gasket so you remember what you're doing and when installing the new gasket so as not to rip or tear it in the process. I'd also suggest you let the gasket relax for a good 4-5 hours (to get the kinks and folds out of it from the packing box) before you do the installation.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WBVH6240F0WW&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00004&componentDescription=TUB%20&%20MOTOR&documentId=G6090504&backToLink=Return%20to%20Sub%20Components%20list
Here's another link to one of my other solutions for installing a bellows gasket on a GE front loading washer that you can also review for more installation tips, etc.
http://www.fixya.com/support/t2730376-need_help_in_installing_door_bellow_ge
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
How do I program the module in an Indesit IWDC6125
indesit washing machines are only made to last just outside the guarentee period these days as the drums are sealed to stop you replacing the drum bearings. much better to buy a reconditioned Hotpoint wm62 they also wash much quicker than any new machine
Mar 27, 2013 | Indesit Washing Machines
Indesitw123 front load washing machine making very loud noise when spinning
The noise you can hear is the drum bearings, the seal between the drum and bearings has failed and let water into the bearings which has destroyed the bearings.
Mar 10, 2012 | Indesit Washing Machines
Clanking machine
Sizeable repair. Basically the seal and 2 bearings need replacement. Very possibly the spider assembly has broken away from the drum. Quickest way to check is to run machine once bearings and seal have been replaced to see if you are still getting any noise and imballance.
Jun 15, 2010 | Indesit W 123 Front Load Washer
Drum bearing
look to see if there are any tamper proof fasteners on the machine, if not then as long as you have torx head and allen wenchs with the other basic tools you should be good to go
Jan 31, 2010 | Indesit WA 125 Front Load Washer
Does the drum have to be removed to replace both bearings and oil seal on an indesit wash machine type we16
No, remove the drive belt pulley and remove the 8 bolts holding the x shaped cast iron frame with the bearings in, lay the washer face down (ensuring adequate protection to the door and controls) whilst pulling the x shaped frame away from the drum tap the threaded shaft lightly with a rubber faced mallet and the frame will come away complete with bearings and seal. To replace the frame (with new bearings and seal installed) I used a large socket and long bolt to draw the shaft through the new bearings.
Aug 05, 2009 | Washing Machines
How easy is it to change the drum bearings on my indesit wil163s?
you will need to remove the pulley first, the screw in the middle will need a knock to release the loctite.
you will then need to remove the spider assembly, that's the metal cross the bearings are sitting in. there are bolts set around the drum. spray the bearings shaft with oil to help removal, and you may need to hammer the spider as you remove it to loosen it. be careful of the heater.
then knock the bearings and seal out and do the reverse proceedure to put back together.
Feb 27, 2009 | Indesit W 123 Front Load Washer
Bearing noise on Indesit WDG1295
you will have to open the machine lid to see if its a plastic drum or metal.
the metal drum is easier as it has a 'spider asssembly'. remove this after taking off the pulley by taking out the bolts that hold it and bang it off being carefull of the heater element. remove the bearings and seal and refit in reverse order you took it off.
i would not advise replacing plastic drum bearings as they are a pain, removal of the rear of a plastic drum easy but not putting it back !
Feb 01, 2009 | Washing Machines
Indesit wash machine drum bearing
depends on the model that you have some indesit machines you only have to undo the spider and others can be a bit of a pain because you have got too split the drum would recomend an engineer regards jason
Jun 13, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine
First of all, what kind of a loud is it making?  Is it a loud squeak, clunk, bang, or jet engine sound?
If it is a loud jet engine sound, then your tumbler bearing is wearing out.  You could try oiling it, but [probably you will have to replace it.  It’s a big job and even if you do it yourself, the best and easiest way to do it is expensive.
I recommend first of all ordering a repair manual.  Or at least see if the parts come with detailed instructions on how to take out the old bearing and install the new.  You will probably have to replace the entire outer drum assembly.  It's much more expensive in parts to do it that way than to just replace the bearings and seals, but much much easier and faster.  Personally, I've replaced the entire drum assembly and also tried to replace just the bearings and seals.  In the end I wasted the money on the bearings and seals and got an new assembly.  I'd recommend just going for the new assembly and saving time.
Oct 14, 2007 | Indesit WA 125 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
