Question about Samsung LA22C450 LCD TV
Stanby led always on. flicker when using remote control but can't power on. the power button on the side of tv has the same effect.
Tried replacing all the capacitors but same problem. However, there are lucky times that the remote power on will work. Any fix?
SOURCE: Remote not working
I have the same TV, and it has developed exactly the same problem! Hopefully there is a solution...
Posted on Sep 23, 2007
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
ltfrc
  • 227 Answers
SOURCE: Side by side Samsung TV's need remote control solution
If possible turn one off and tune the other. Then turn the other off and tune it. Then turn on the other. That is your only option at this point.
Posted on Feb 16, 2009
Shuttle83
  • 1139 Answers
SOURCE: No Video, No Sound
Hello, This might be a board with a loose connection or a faulty capacitor on the power board or one of the immediate circuits attached to the power supply board. I would suggest that you have this serviced by a qualified TV Technician. However if you wish to do this yourself, you need the following equipment: 1) Multimeter (to measure the voltages; AC and DC on the various test points on the boards) 2) Oscilloscope (to measure the startup and shutdown circuit ramp voltages) 3) Isolation Transformer (to isolate the Tv from the AC circuit that the test equipment is on) 4) Service manual or schematic diagram (to show where the test points are and what signals and voltages to expect) 5) Signal generator (to generate reference signals for servicing the TV) Now if you know how to use these pieces of equipment your are ready to start, if not again I would advise you to have the set checked by a qualified TV repair technician. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 10, 2009
  • 32 Answers
SOURCE: I cannot adjust the volume on my Samsung 42" Plasma (PN42a400)
its called a sleep timer. when it does come back on you need to find the sleep timer program ans turn it off
Posted on Jul 12, 2009
How do i get the codes for a GE universal tv remote
You can programme your remote by below method
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
You can get your codes from below website
http://www.jascoproducts.com/support/universal-remote-codes.asp
Thanx
Dec 10, 2010 | GE Televison & Video
Codes for ge universal tv remote and how do i program it?
Manual code entry
Auto configuration
Thanx
Oct 05, 2010 | GE Televison & Video
I need the codes for ge universal remote controller model #J021
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | GE RM24930 Remote Control
I need the codes for a magnavox
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | Universal Remote Control GE174Universal...
What are the codes for a zenith tv? I cannot find my manual
Manual code entry
Auto configuration
Thank You
Sep 19, 2010 | GE JASRM24912 Remote Control
I would like to help me program my remote control my TV, I hope is a trademark relistic solve my problem thanks
Manual code entry
Auto configuration
Thanx
Aug 07, 2010 | GE JASRM24912 Remote Control
I don't know the code or how to program it to my magnavox tv or zenith dvd/VCR player
Manual code entry
Auto configuration
Thanx
Aug 05, 2010 | GE RM24912 Universal Remote Control
To program my TV JVC
Manual code entry
Auto configuration
Codes for JVC TV are
3 digit codes:
013, 012, 026, 054, 055, 060, 065, 067, 069, 089, 141, 197, 247, 901
4 digit codes:
0060 0026 0197 0069 0160 0247 0923 0012 0065 0067 0141
Thanx
Aug 04, 2010 | GE JASRM24912 Remote Control
My GE Universal remote no longer works. The battery is fine but the signal is no longer working on my TV. I would like to try to reset the remote to my TV.
Please try to programme your GE remote to your TV
Manual code entry
Auto configuration
Thanx
Aug 04, 2010 | GE RM24930 Remote Control
Need code for slyvania tv & instructuins on how to do it
GE
Manual code entry
Auto configuration
Thanx
Aug 01, 2010 | GE JASRM24912 Remote Control
Samsung LA22C450 LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
