Question about Kitchen Appliances - Others
Phillips deep fryer HD6161 has stopped working
The red light is on and digital display is flashing
SOURCE: Deep Fryer stopped working.
I had the same problem, but I fixed mine!!!! Make sure that the part with the control panel is locked in. It you just sit it in, it won't come on. You must lock it in on the side.
Posted on Jul 09, 2008
SOURCE: Deep fryer not working
May Blow Your Fuse Replace the fuse
Posted on Jul 18, 2008
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
  • 43 Answers
SOURCE: fryer not working
I also have the 4320 and my problem was a reset button on the back, down in a hole.
My reset button is red. Also there is a safety swith on the rear where you slide the control
unit into the grooves, it has to be all the way down for it to work.
Posted on Jul 04, 2009
SOURCE: My waring pro deep fryer is not heating up. How can I fix it?
There's a little black button on the bottom of the head unit which needs to be seated proproperly for it to turn on. Make sure this is in the right spot or move it around some and re-position it to see if that helps.
Posted on Sep 26, 2011
Why did it stop working?
Big Boss™ Oil-Less Fryer - BedBathandBeyond.com
www.bedbathandbeyond.com/.../big-boss-oil-less-fr...
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Big Boss Oil-Less Fryer Reviews and Complaints - Genuine ...
www.asseenontvonsale.com/kitchen/big-boss-oil-less-fryer/
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
BIG BOSS KITCHEN PRODUCTS - Facebook
Dec 25, 2015 | Big Boss Oil-less Fryer
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
Deep fryer model f1063b red light goes on. not the green light. no heat
hi limit is tripped, look for the red reset button and reset it.if the red light is still on after resetting, replace the hi limit device.
Mar 02, 2011 | Bravetti Kitchen Appliances - Others
My deep fryer stopped working while frying. How
id look in the right side groove and you will see a tiny microswitch that wont allow power to the element unless its sitting in the cradle I simply took the 4 screws off in the back of the heating element control and by passed it by connecting the 2 red wires and it worked so now I got to find the microswitch but at least I can use it
Dec 22, 2009 | Tefal Ultimate EZ Clean Pro Deep Fryer
Fryer not working
Jun 29, 2009 | Bravetti K4320H Deep Fryer
Please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Jul 08, 2008 | Wells LLF-14 Deep Fryer
Kitchen Appliances - Others Logo
119 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
