Why does it keep switching itself on during the night, with full picture and everything and staying on?
Usually around 4-5 am, round about the time of software check (or so I am told), it turns itself on and stays on until it is physically switched off
    Scholar:
  • 86 Answers
I like Ray's answer. By putting it on a power strip, when you turn off the power, it'll be the same as if you unplugged it. It's a good test even if you don't keep it this way as it would also disable the ability to turn on/off with the remote control.
Posted on Apr 15, 2015
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Main system control memory IC fault is the first reason.
The second one is, from somewhere the set receives ON signal; either from its remote control, or from the surroundings. Some CFL lamps can generate infrared rays to energize the infrared sensor inside the TV to switch it ON. http://electronicshelponline.blogspot.com/
    Top Expert:
  • 43,079 Answers
Problem getting BlueTooth to stay on on my tablet
This usually is fixed with a full reset. So backup your stuff first and then reset it
Mar 18, 2016 | Tablets & eReaders
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
AquaLink RS8 switchs itself from Pool to Spa pump
make sure no programs if ok remove spa side remote plug if ok then replace spa side remote istill does it reset board but before write down all auxs and jvas
Mar 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Sometimes during night several times try to start
it sounds like the fflame sensor needs to be replaced, however if the unit has fan assited combustion you may also have an issue with the pressure switch. hope this helps
Nov 02, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Our fan light comes on all by itself in the night. the fan itself does not always respond to the remote, mostly when turning on. I had to replace 85112-02 a couple of times when the fan was new. Now what?
Your power is going off and back on during the night (that, or a poltergeist is pushing your power switch. :-). The Hunter 85112-xx is programmed to turn the light on when power has been off and is restored (this is so you can turn it off/on with the wall switch as well as with the remote). No way that I know of to get around this. I find it VERY annoying.
Jul 10, 2009 | Hunter Ceiling Fan Remote Receiver...
Right front electric window keeps opening by itself
it probably corroded the motor and or contacts. You can either take the motor out and try to clean it using elctromode, or replace it
Check ebay, they usually have a good aftermarket laying around for much cheaper than a dealer ship
Feb 06, 2009 | 2001 Audi allroad
Humax PVR 9150T Switching on in the night
I think the PVR is trying to update the software but is obviously unable to do so.
Dec 09, 2008 | Televison & Video
Using a 70/200 lense with a annon 40D at a football game at night
to get good pictures you have to stay at least at the same speed as the aperture:
100mm - 1/100sec mini
200mm - 1/200sec mini
if you are in automatic mode, the camera says" there is no enough light, the aperture is max (f:2.8 or f:4) so i shut down the speed." and go against the rule. you have several solution:
1 you stay in automatic mode and take yor photos with a tripod.
2 you put your camera in speed pririty, with the good speed, and try not to moove during the shoot (you can put your camera on something stable)
3 you tune up the iso
4 2+3
Oct 02, 2008 | Nikon Lens Hood, Lens Cap for D200
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
