Question about Kyocera FS2020D ECOSYS Monochrome Laser 35ppm USB20 Parallel Interfaces 500 Sheet p Printer
How do I get it out of envelope mode - Kyocera FS2020D ECOSYS Monochrome Laser 35ppm USB20 Parallel Interfaces 500 Sheet p Printer
  • 523 Answers
Change the cassette settings and bypass settings to letter size. sometimes there is a wheel inside the cassette itself, turn it until you see the letter size.
Posted on Apr 25, 2015
    Top Expert:
  • Kyocera Master
  • 43,095 Answers
Usually when you try to print another box appears to set paper size and type
Posted on Apr 14, 2015
WHAT IS THE THUMPING NOISE WHEN PRINTING?
Two possibilities I can provide:
1. The fuser pressure roller is out of round and the noise is the flat spot hitting the hot roller on every rotation.
2. These printers have an envelope mode that activates a solenoid in the fuser when printing envelopes to force air out of an envelope.
If it makes the noise constantly then it is the fuser. If only as the page is exiting then it is the envelope mode.
Oct 09, 2014 | Lexmark T634 Laser Printer
Match envelop swiches how i can fix it
To turn off envelope mode open the rear door and slide out the Fuser on top you will see 2 green push buttons push them to realease and machine should be out of envelope mode
Nov 06, 2013 | Kyocera Fs-3920dn Laser Printer
I can't get envelopes to print at all from word to my HP4350, I have reset printer to envelope mode on tray 1 and still nothing. The printer says no jobs are pending. The two are not "talking" t
There may be a problem with the print driver. Try deleting the printer from your computer and then re-adding it. Print driver can be downloaded at www.hp.com. in case you have lost your installation CD. Good luck !
Apr 15, 2013 | HP LaserJet 4350 Printer
How to keep the envelope from wrinkling during printing
Are you using proper laser envelopes? The machine should also be set on envelope mode (When you put your envelopes on the bypass tray the machine should ask what kind of paper you have put in there - just select envelopes).
Oct 08, 2012 | Konica Minolta Bizhub C220 Color...
Kyocera FS4020 - how do I get it out of envelope mode
When you start print there is a option to change it,i guess is like "properties" hit it and change the configuration.
Apr 18, 2012 | Kyocera Mita Office Equipment & Supplies
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I would like to feed and print an 6" x 9" envelope
Print 4" x 6" photo images in normal mode in about 60 seconds; up to 17 ppm ... 3/4 Envelope. 9 Envelope. A4. A5. B5 Envelope. C5 Envelope. DL Envelope. 6 3/4 ...lexmark.com/lexmark/product/home/15/...?tabId=1
Dec 04, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
How do you load an envelope in the printer?
Hi, Please follow these steps to load :-
1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
  1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
    3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
    4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
    5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
    6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
    7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
  2. Thanks!
Oct 02, 2009 | Office Equipment & Supplies
Change from envelope to paper mode?
Scroll through the paper handling menu and select CASSETTE FIRST
Jan 08, 2009 | HP LaserJet 2420 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Kyocera FS2020D ECOSYS Monochrome Laser  35ppm USB20  Parallel Interfaces 500 Sheet p Printer Logo
106 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
