Question about Whirlpool Washing Machines
My Whirlpool WSF1071BD won't take in water, it keeps saying a clean pump error, I've stripped & clean everything, could it be the plastic ball in the drain tube under the drum, pump is still running?
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Probly is ball stuck
Posted on Apr 27, 2015
SOURCE: F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
Posted on May 20, 2007
  • 883 Answers
SOURCE: Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Posted on Sep 16, 2007
SOURCE: whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Posted on Mar 20, 2009
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
  • 662 Answers
SOURCE: Frigidaire Affinity E20 code without washer draining?
Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
You can give me a very helpful rating for the free help, can't you. Thanks.
Posted on Jun 13, 2010
After replacing valve coils it now makes thumping noise reassembled it twice
Thumping noise is usually something with the drum system. You didn't list make and model so I'll give a few suggestions. If its Whirlpool--- the drum rides on 2 rubber rollers at the back edge that wear and need replaces if the rubber gets too bad. The front edge of the drum has a 2 piece plastic bearing strip that snaps into square holes in the front drum edge. Those 2 strips sometimes break or chip and need replaced.
If its a Frigidaire dryer----the back drum bearing is a small round metal ball that looks like a small trailer hitch ball. If fits inside a slotted plastic retainer block. The plastic block wears and the ball sometimes gets grooved and needs replaced. It comes as a complete kit (ball and socket) for about $20. The front of the drum has a similar system plastic strip as the Whirlpool I described above. Hope this helps.
Jun 10, 2015 | Dryers
Clean Pump light keeps coming on
What is the model number of your unit?
Nov 10, 2012 | Washing Machines
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
F02 error code whirlpool washer. Already replaced drain pump and cleared hoses. Problem (code) still occurs. Do I need to reset something?
Considering what you've already tried, I'd suggest it is an error with the check ball in the tub to pump bellows.
Try this link, (you made need to copy & paste to your navigation/tool bar)
http://fixedappliance.blogspot.com/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
omit the talk of detergent and pump cleaning since you've done that and instead focus on the check ball device that commonly gets stuck and initiates an F2/ F21 error on these washers.
For an abbreviated version, check out an earlier solution I posted here on Fixya a while ago...
http://www.fixya.com/support/t10901030-washer_wont_drain_he5t_code_f21
I don't participate here much nowadays, too busy. In fact you'll find many the same problems & solutions under my profile.
Good luck.
Regards,
Macmarkus :)
Jul 04, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool calupso FL (over fill) flashes....The manual says the washer will beep every 10 seconds and the pump will cycle one half minute on, one half minute off until the over fill switch is reset or the...
Hello & Welcome to FixYa
FL error indicates flood condition and is caused due to any overfill condition that occurs inside the washer. To clear the display you can press and hold the STOP/CANCEL button. Usually this error is caused when overfill switch trips due to excessive water in the tub. You can also try to clean the drain hose and check the water inlet valve. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Epson Stylus Photo R280 general error The printer has worked fine for years. All of a sudden 'general error' starts coming up. I understand this to be something is jammed in it. When I turn it on...
Hi John
This is a problem with the Encoder sensor hence you need to clean it and make sure there is no Ink on it. The encoder sensor is the sensor which is at the back of the carriage where you can find a plastic strip.
By cleaning it the problem will be solved
Another senario
If the capping unit is having problem only then this error appears. Check and make sure the capping unit is working well.
(Capping unit is on the right side of the printer where the carraige is parked when it is turned off)
Sep 08, 2011 | Office Equipment & Supplies
Whirlpool washer ghw9150pw0, error message f02. I have removed, cleaned and checked all drain lines and checked backflow ball. everything is good. May I assume the pump is bad.
HELLO THERE AND THANK YOU FOR CHOOSING FIXYA
The f02 error code is a long drain error meaning the following and here is what needs to be checked before replacing the pump
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jun 06, 2011 | Washing Machines
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get...
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
May 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
