Question about Fisher & Paykel Paykel E521TLX2 Fisher Paykel 79cm Frost Free Fridge Freezer Left Hinge
Trips the fuse in the fuse box for the house when switched on
    Top Expert:
  • Fisher & Paykel Master
  • 50,296 Answers
Call a repairman you got a dead short probably the compressor motor
Posted on Apr 14, 2015
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
Wont heat up
Good Morning Johnnie, thank you for your post!
Often when a dryer no longer heats, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and one also may have tripped. Typically, the heater of a dryer requires 220 to 240 volts to operate. If none of the tips above solve the issue, then it could potentially mean a number of other things: defective cord, a wiring failure, faulty heating element, or control board. Which in the case, I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Sep 10, 2013 | Frigidaire Dryers
Buttons, sounds, lights all go on but the dryer will not dry
Hello toofdr - Often this occurs because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn on but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jul 12, 2013 | Frigidaire GLEQ2152ES Electric Dryer
No heat
Check if you soldered it correctly, if not, the relay might have been damaged, you might need a new one
Jun 25, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Affinity panel turns on (lights up), even counting down, but the dryer won't tumble or heat. Help?!
Hi margaretc920 - Often when a dryer turns but will not heat, it is because either a fuse from the fuse box is blown or the switches on the breaker tripped, depending on your house. If your house uses fuses, there are two house fuses that supply voltage to the dryer circuit in your fuse box. If one of the two fuses is blown, the unit may turn but will not heat. Check and replace fuse in fuse box if necessary. However, if the house has circuit breakers, there may be two breakers with switches that supply voltage to the dryer and if one is tripped the unit as well will experience this issue. The heater of a dryer requires 220 to 240 volts to operate. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If the issue persists, it could also potentially mean a number of other things: defective cord, wiring, control board or door switch. I would personally contact a professional to accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Jun 16, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
When my fridge is plugged and turned on,it causes the circuit breaker of the distribution board feeding that part of the house to trip off. what could be the cause(s)?
well there is only one solution to that,your fuse box must be having a problem of what is called the sdc self dissconnect circuit now what you do is check your fuse box if the switch of that part of the house is off then call an electrician cause it is highly risky
Jun 29, 2012 | Refrigerators
When the dishwasher is drying the load it blows the electrical fuse
There most likely is a problem with heating element or a wire shorting
Nov 07, 2017 | Neff 24 in. S5453X1 Built-in Dishwasher
When fan is turned on, all electrical power in house goes off (safety switch is tripped). This happens even when the fan light is off.The fan is an older model (i don't know what brand) that was in the...
It may be possible that fan wire is connected to another wire, so it is short circuited. Thats why safety switch is may be tripped... Check the connection of the wire.
Mar 05, 2010 | Heating & Cooling
Fisher & Paykel Paykel E521TLX2 Fisher Paykel 79cm Frost Free Fridge Freezer Left Hinge Logo
85 people viewed this question
Top Fisher & Paykel Refrigerators Experts
x-ray man
ray gallant
Charlotte Sharp
Charlotte Sharp
Are you a Fisher & Paykel Refrigerator Expert? Answer questions, earn points and help others
