Question about Blinglights 1996 1997 1998 1999 2000 Honda Civic Halos Fog Lamps Angel Eyes Driving Lights Foglamps Foglights
Wiring ford rangerfog
Fog lights have a relay?fuse? wiring diagrahm
High bam and fog lights that just stopped working
Disconnect one of your headlamps and use a multimeter to figure out the positive low beam and ground on the wiring, then using the ohm meter function check the high beam wiring back to the fuses and relays.
If I remember correctly, the fog lights are supposed to turn off when you turn on the high beams. So that switch system may need to be looked into on the controls.
Aug 16, 2016 | 2003 Ford Explorer Sport XLT
Fog light install
Yes you can, if by fog lights you mean after market ones., Just takes a switch, wire, 40 amp fuse and 5 pin relay, soldering iron, wiring conduit, sharp edge to bare wire, wiring diagram and some insulation tape.
Mar 22, 2014 | 2000 Honda Accord
My NISSAN NV200 2011 front fog lights do not work.
Both fuse and relay are located in engine compartment fusebox.
Click the link below to go through fuse box diagram:----
http://schematicsdiagram.blogspot.com/2013/02/nissan-fog-lamp-relay-and-fuse-box.html
This will help.
Thanks.
Feb 14, 2013 | Cars & Trucks
My fog lights won't work but switch shows power, however when hit the switch can hear the relay on passenger side fuse box can hear it click does that need replaced
Hi, if the light on the switch is coming on, the relay is fine. Unless both bulbs are burned out, the problem is in the wiring between the relay and the lights. I recommend you trace the wiring backward from the passenger side fog light to the power box under the hood to see if the wire is cut. There should be two wires coming out of the power box--one going to each fog light. If the wiring looks good, it is also possible that the ground to the lights is bad.
Aug 29, 2011 | 2000 Oldsmobile Alero
I want to add fog lamps to my '01 Mustang convertible. I can get the lamps, brackets & dash switch from Ford at reasonable prices. My question: Does the existing wiring harness include wiring for the...
i dont think current wiring harness is set up for fog lights but fuse box should have a spot for relay and fuse (although it may or may not have metal leads installed) if your getting parts from ford i ask them if they have wiriring harness for it
if you decide to wire them in yourself i would HIGHLY recomend u put a relay in the system if you dont you will have to use bigger wire tho the whole sytem. with a relay u only have use the bigger wire from relay to lights. You will also have to use a heavy duty switch u will burn up factory switch if dont use a realy
Feb 17, 2010 | 2001 Ford Mustang
2001 silverado- I am trying to install factory fog lights in my truck and i installed the button, bought the relay, and installed the lights. I got the wires for the fog lights from the junkyard but am not...
GM installs wiring harnesses and fuse blocks configured according to the original options for the vehicle. While the fuse block may have a spot for the relay, that doesn't mean the wiring is installed under the block for it, and that presents a problem as contacts in the block are pressed in and wired for specific options, and may be missing for this option in your truck. Even though you may have the fog light wires to connect to the relay and there is a place for the relay in the fuse block, there may not be the necessary relay socket connectors installed and they are almost impossible to retrofit (although you can try if the fog light wires you have also have the correct connector on the ends).
You can check if all necessary relay socket connectors are installed, and if so, you could try to figure out which wire is installed for the connection you are trying to make, and connect the purple wires to that wire. Otherwise, you may have to install the relay away from the block, and then make the necessary wiring connections (power, ground and output) to it.
Jul 14, 2017 | 2001 Chevrolet Silverado
How to factory wire fog lights on a 2000 ford f150. pig tail, relay, and fuse are there. Only no wiring from fuse box.
This is a common problem on 97-00 MY trucks, regardless of the trim level ( XL, XLT, Lariat ).
If you install the fog lamp fuse in the BJB ( aka Battery Junction Box, Engine Compartment fuse panel ) Fuse # 9 ( 15 A fuse ) and jumper the normally open contacts in the fog lamp relay socket ( see diagram below ) the fog lamps should illuminate ( to confirm what you have doing on ).
The problem usually is the main headlamp switch to the BJB is not in place ( this is the yellow wire from the main headlamp switch connector to the relay socket pin #1 ).
One easy route is to make an aux lighting relay & harness, or purchase one online. With this, you can cut the factory ends and attach them to the harness you purchased. There is an air inlet next to where the steering wheel column runs through the firewall. This would give you an easy route to the fog lamp switch. The fog lamp switch, you can buy the factory one, and change the yellow wire from the connector to your added relay, or just add a switch for this function.
This will give you an idea of what the DIY relay and harness would look like.
Hope this helps, more than confuses at this point
Sep 16, 2009 | 2000 Ford F150 Flareside SuperCab
Wiring of fog lights on 95 Mustang
If you bought the fog lights from Ford and they plugged into factory plugs at the front bumper, then I suspect you need the headlight switch that came optional for your car. You will need to install a relay into the fuse box. Check for any fuses for that circuit. I did one on a Ford f-150 and the switch came with the lights from Ford.Usually the fog lights are not on until you push a button or turn the switch.
Mar 15, 2009 | 1995 Ford Mustang
09' hhr fog light wiring
You will need to completely wire your own setup. The "stock" fog lights on the HHRs are wired through the Body Control Module computer which can not be reprogrammed without being replaced. Cost of the computer is over $300 and certainly NOT worth it for a set of fog lights. Put in your own switch, wiring, etc. I would highly recommend that you use a relay to power them since the electrical system for the HHR is very sensitive to external additions.
Mar 09, 2009 | 2008 Chevrolet Hhr
Blinglights 1996 1997 1998 1999 2000 Honda Civic Halos Fog Lamps Angel Eyes Driving Lights Foglamps Foglights Logo
505 people viewed this question
Top Blinglights Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Blinglights Garden Expert? Answer questions, earn points and help others
