How to reset 1993 Geo Prism radio
Change battery radio needs to be reset
SOURCE: gas tanks
yes from 1993 thru 1997 everything is interchangable
Posted on Mar 26, 2009
rcampsr
  • 90 Answers
SOURCE: Need to know what wires are for what to change out
The best thing you can do for your situation is to get a vehicle wiring diagram for your particular vehicle. This can be done at the dealer or by buying a vehicle manual at the autoparts store that has the wiring diagrams in it. You can then see the wiring color coding. They also make a factory plug pigtail that you can plug into your existing radio harness and then wire it correctly to the new radio. The new radio should have the wiring layout included with its documentation, and some radios also have small marking tabs on the wire ends to tell you what they are for. Good Luck, RAC
Posted on Apr 18, 2009
  • 6 Answers
SOURCE: radio locked on 94 geo prism
take the power off of the battery and leave for 5 min then plug back up also try removing the fuse for the radio located under the dash
Posted on May 19, 2009
mcgyver468
  • 710 Answers
SOURCE: does the alternator on a 1993 Geo Prism need grounded?
IF THE WIRE THAT IS HANGING HAS A TERMINAL ON IT WITH A LOOP, THEN LOOK ON THE ALTERNATOR FOR A STUD THAT MAY ACCOMODATE THE WIRE'S LOOP. IF THE WIRE HAS A PLUG THEN LOOK FOR A CONNECTION ON THE BOTTOM OF THE ALTERNATOR. IF NOTHING IS ON THE END OF THE WIRE, THEN HEAD FOR AN AUTO PARTS STORE WHERE THEY WILL HAVE THE APPROPRIATE PLUG OR WIRE CONNECTOR FOR YOUR VEHICLE. HOPE THIS HELPS. THANKS FOR USING FIX-YA. GOOD LUCK. AND THANK YOU IN ADVANCE FOR AN HONEST RATING.
Posted on May 23, 2009
  • 28 Answers
SOURCE: is there a synthetic freon for a 1993 geo prism?
freon which is known as R-12 in the industry was replaced with R-134A which is the refrigerant used in your car.. There is a user available replacement which comes in a one pound can that can be installed, however you must have the system evacuated by a garage in order to install it..
Posted on Jun 07, 2010
Remove alternator
why do something dangerous with no books.?
1: pull neg, battery lug, first and only.
2: pull all wires off Alt.
3: loosen all pivots bolts, (can be 3 )
4: drop the belt.
5: pull off all bolts on alt.
6: alt falls out.
tools?, 8mm to 21mm..
well a full set of open end box wrenches (metric) and 3/8" drive socket sets are the minimum to work any small car.
at the least, there are more, tools,
screw drivers
Pliers.
Nov 27, 2013 | 1993 Geo Prizm
Replace battery cable ends 93 geo prism
cut old wires off with lineman pliers go to auto zone and buy 2 ends weather it's side post or top post and strip about half a inch of the insulation off and tighten the bolts down
Jul 23, 2012 | 1993 Geo Prizm
My brake lights won,t go on in my 1993 geo prism
I would check the brake light fuse and the brake light switch under the dash on the brake pedal lever. And, of course, check the bulbs themselves.
Oct 19, 2010 | 1993 Geo Prizm
Is there a synthetic freon for a 1993 geo prism?
Jun 07, 2010 | 1993 Geo Prizm
Does the alternator on a 1993 Geo Prism need grounded?
May 23, 2009 | 1993 Geo Prizm
Radio locked on 94 geo prism
May 19, 2009 | Car Audio & Video
Locked radio
THE CODE IS SPECIFIC TO THAT RADIO.U NEED TO CALL THE DEALER W/THE SIERIAL NUMBER OFF THE RADIO & VIN NUMBERS OFF YOUR CAR.THEY WILL GIVE U THE CODE.
May 05, 2009 | 1997 Geo Prizm
Need to know what wires are for what to change out stock radio in 1993 geo prism, to a new radio iDA-x200
Apr 18, 2009 | Car Audio & Video
Gas tanks
Mar 07, 2009 | 1995 Geo Prizm
361 people viewed this question
 Grubhead
Grubhead
