Question about Exercise & Fitness
I receivd bh elliptical ocean program with no power cord.The sticker on trainer is torn,it has 6v but thats it. Googled & found nothing on Power cords or power sup needed to turn on thanx again,kirsti
  • Kirsten thomas Apr 16, 2015
    Or even where i could purchase over internet or any store in victoria, australia. I also would purchase power cord from england as hav plug english plug conection. I have found universal cord at electrical store but they say without amp supply needed no good. Thanx again, kirsti
  • 914 Answers
It could be that the BH elliptical you have does not need an external power supply, but it does need a new set of batteries in the console.
For example:
The X8 BH elliptical is self powered, when a user strides at a speed about 20 RPM's; electricity is generated to allow the console to function properly. Exercising recharges the batteries in the console.
If you want to take a look at the X8's manual as a reference to see where the batteries are located in the console you can check it out here http://www.gophersport.com/files/pdf/GS68997_BHFitnessX81.pdf
We hope this helps in any way :) if you ever need a little help trying to figure things out you can chat with us at www.sportsmith.net or by phone at 888-713-2880
Posted on Aug 18, 2015
SOURCE: power cord?
you can find the power cord at fitnessrepairparts.com
Posted on Jul 06, 2009
  • 95 Answers
SOURCE: The power cord for my
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Posted on Apr 19, 2011
  • 23 Answers
SOURCE: I need some replacement parts for my elliptical trainer. Where can I find them?
The first thing you should do is check with your manufacturer. Not only should you be covered by warranty, but they should have the right parts for your machine. If your warranty is expired or the manufacturer has gone out of business, you should look elsewhere for parts specific to your machine; however universal parts may also do the trick. If this is the case, you may want to consider buying used parts.
Posted on Aug 02, 2012
  • 3 Answers
SOURCE: My Precor EFX 5.17i elliptical trainer keeps displaying "Error 40" even when I turn it off and back on. How can I fix it?
try puting in new baterrys
Posted on Mar 10, 2013
  • 241 Answers
SOURCE: user manual for Kettler 07854-000 "Orion" Cross-Trainer Elliptal
Try here
http://toolbox.kettler.net/fileadmin/_kettler_dam_import/SPORT/Dokumente_-_Kataloge/Montage_und_Ersatzteile/Cro(ss)trainer/07854-_Orion_706f-1003.de,en,fr,nl.pdf
Posted on Oct 28, 2014
My precor 517.1 elliptical does not turn on
I would start the troubleshooting process by confirming power at the wall outlet. If this checks out, follow power from the wall to the end of the cord. If you still have power at the end of the cord, check the power inlet. If you still have power on the back side of the power inlet, you may be looking at a bad control board. Repair Parts for Precor 5 17 5 17i Ellipticals Consumer SPORTSMITH net
Sep 28, 2014 | Exercise & Fitness
Nordictrack elliptical asr 700
Hi There,
There may be a problem with a power wire inside the machine.
Ring Icon Fitness to repair.
Aug 24, 2014 | Exercise & Fitness
What voltage does this model run on,24volts?
The details regarding volts current etc should be in the back of your manual
Jun 17, 2014 | Exercise & Fitness
My Schwinn 420 elliptical is not powering on. The breaker and outlet source are fine. When I plug the machine in nothing powers on. The console displays nothing, no lights, etc.
test the power cord plug, in another device and see if working
2) replace batteries if your system has( clean the contacts from oxide,corrosion with contacts cleaner) and try again when you have isolated the problem
God bless you
Nov 05, 2013 | Schwinn 420 Elliptical Trainer
Power supply
Call Treadmill Doctor at 800-750-4766, they can steer you in the right direction.
Jun 16, 2012 | Multisports Elliptix Ect 6600L Cross...
Won't turn on
Check the battery and or power cord for the proper voltage.
Video about How to Test Battery
Jan 26, 2012 | Precor EFX 546i Elliptical Version 4
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
My Schwin 430 power cord socket went inside the machine. Please advice how to power the machine.
There should be a series of phillips head screws (star) holding the black casing together. If you remove the 2 or 3 screws along the immediate front of the case, you should be able to open it up just enough to see the outlet. It's a small plastic piece about the size of a grape attached by two wires (red and black). The outside of the outlet is threaded so when it's pushed through the hole, you thread a nut on the outside to hold it in place. If you've lost the nut, you can easily tape the outlet in place, or just run the ac adapter cord in through the hole in the case, use the opening at the front you made by removing the screws and plug it in on the inside to power it. Replace the screws and just make sure you keep anyone from yanking on the power cord.
Jul 06, 2010 | Schwinn 430 Elliptical Trainer
Where can I get a power cord for a Endurance E7 Exercise Machine?
Call Body Solid @ 1-800-556-3113 Ext 520 for customer service they will help you.
Jun 25, 2010 | Endurance E7 Elliptical Trainer
Power cord?
Jun 02, 2009 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
681 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
