Question about Echo Garden
Vintage Echo CS-302. Ran for years with zero problems. Until now. It starts and runs great for about 320 seconds. It will rev to max rpm, then it starts dying. wah, wah, wah,, shuts off. Repeat,same
    Top Expert:
  • Echo Master
  • 45,569 Answers
Check for problems in the carby--replace with a kit
check the filter on the end of the line in the tank-- they tend to block up
check for blocked exhaust--- carbined up inside
don't use E fuels as they will not operate on the E mix
Posted on Apr 14, 2015
  • Echo Master
  • 2,760 Answers
Got a echo that did this from a yard sale , turns out the piston was ruined by former owner that ran straight gas thru it
my saw requires a gas/oil mix in the 32/1 ratio if not it will overheat and lock up
Posted on Apr 15, 2015
Testimonial: "I haven't tried it yet, but the fuel filter in the thank might just be the problem.. Worth checking that out before ripping the carb apart.. thanks."
Cs-302 fuel line replacement
How do I remove the Flywheel on a 1982 Echo chainsaw 302? I can't get to the fuel line since a piece got stuck under the flywheel.
Feb 01, 2014 | Echo Cs-302 Flywheel Assembly Cs 302
I have a 1994 v-max Sled ran until cables were
you may have fried the ecu
Sep 12, 2013 | 1994
Echo Trimmer starts but won't run
Replace the filter in the gas tank. Sounds like it is mostly plugged.
Jul 10, 2017 | Echo Garden
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Can't get my echo to rev up
Your carburetor needs cleaned, or you need a new carb. kit. If you need tips on how best to do this, let me know.
Jim
Jun 03, 2009 | ECHO, Inc. PB-251C Handheld Blower
Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
Echo CS-302 chain saw with no instructions (Inherited)
the echo cs302 is equiped with an automatic oiler that lubricates when the engine is running the manual states the unit runs on a 20:1 mixture 89 octane fuel with 6.4 oz of tcw3 oil per gallon
Apr 10, 2009 | Echo Garden
Garden Logo
196 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
