Question about Kenmore Sewing Machines
I have Kenmore sewing machine model 385.19112. The stitch is loose and jumps. I followed all the instructions in the owner's manual but I still have that problem and on all fabrics. What can I do?
    Master:
  • 661 Answers
So many reasons for this.
1) the needle is not inserted correctly.
2) the needle is damaged.
3)the foot is not attached correctly.
4) the machine is not threaded correctly.
5) wrong needle size for the fabric.
6) Poor quality thread.
7) Bobbin case not threaded correctly.Hope one of these helps.
Posted on Aug 02, 2015
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 237 stitches loose on bottom of fabric
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
bargainbox.com.au
Posted on Sep 02, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
How to oil a kenmore 12 stitch model 1284180
Consult your owner's manual and use ONLY fresh, good quality sewing machine oil. It is important that you oil according to the instructions provided.
Nov 03, 2015 | Kenmore Sewing Machines
The stitch length is frozen on zero. was fine and i moved toward back stitch. It stopped and locked down at zero stitch length. Please advise.
Your sewing machine probably needs cleaning and oiling. Follow the instructions in your owner's manual and use ONLY recently-purchased good quality sewing machine oil.
Oct 11, 2015 | Sewing Machines
Kenmore 385.18221 auto bobbin shut off does not work how to fix? where to get repair manual?
Hi Freysauto,
You can obtain the Owners Manual here: Instruction Manual Kenmore 385 18221 Models
'Manage My Life' reports "There is no service manual offered for your model sewing machine. Some of the older sewing machines didn't have an owner's manual and service manuals were offered for them. There is an owners manual for your sewing machine, but no service manual." Can download service manual for Kenmore sewing machine 385 18221...
Good luck.
Feb 12, 2015 | Kenmore Sewing Machines
I have a Kenmore 385.16764 sewing machine which I am unable to set the bobbin tension on. I have followed all the instructions in the manual, but the bobbin thread is still too loose.
If you have followed the instructions EXACTLY you should be able to adjust the stitching tension as shown on page 28.of the Manual
Think , has it only just started doing this ? and what you do did before it went wrong.
Try and narrow down yourself as to when and why it went wronf. The answer will nearlt always be in the Manual. Download here
http://data.manualslib.com/pdf3/60/5934/593381-kenmore/38516764.pdf?c61568ad2cd391708580f304a7f5de09&take=binary
Have you tried another bobbin ? The threading of the bobbin is crucial
Take all the threads off and start again.and follow the manual..
Try Straight AND zigzag stitching to see if it is a machanical fault.
Failing all that, It is back to the Repair Shop.
Sep 18, 2014 | Kenmore Sewing Machines
I have a Kenmore sewing machine Model 158.17030. It's an older model and I don't have the user manual. I can't figure out how to set it on the hemming stitch. No matter what I do, it just sews a straight...
Hi. First, I'd recommend you get a replacement manual. They are really useful. Check out http://sewingpartsonline.com/sewing-machine-instruction-manuals.aspx.
I assume you have different stitches on the machine and a diagram of some sort showing what each stitch looks like. Find one that looks like:
---^---^---^--- (maybe on its side). That's the blindstitch. Some machines require you use a blindstitch foot with the stitch, but some don't. Without the user's manual, it's hard to say what your machine requires.
Good luck and let me know what happens.
Robbie
Jan 10, 2010 | Kenmore Sewing Machines
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
