Question about Epson Office Equipment & Supplies
WHY MY EPSON L120 CANNOT PRINT. THE MESSAGE ERROR -1004 POPS UP.
I RETURNED TO THE DEALER BUT THE PRINTER PRINT USING THEIR COMPUTER. THEY SAID NOTHING WRONG W/ THE PRINTER.. WHAT IS WRONG THEN? I UNINSTALL AND REINSTALL, BUT JUST THE SAME, ERROR 1004 STILL POPS UP. IT CANNOT PRINT. PLEASE HELP!
  • ray gallant Apr 14, 2015
    then you need to reinstall it on your computer
  • Josie Deypalan
    Josie Deypalan Apr 14, 2015
    I REINSTALL IT BUT THEN AGAIN ERROR 1004 STILL POP UP. IT CANNOT PRINT.
    Top Expert:
  • Epson Master
  • 44,351 Answers
BRAND NeW return to place of purchase under warranty is it not
Posted on Apr 14, 2015
Good day. i am using the ssc service utility to reset the waste inkpad counter for my epson l120 but error does always appear how could i fix this? please give me an exact solution to this? thanx..
You can't use SSC service to reset this printer EPROM.
The best solution to reset this printer by using Epson Adjustment program for L120 which you can get it from the other sites(for free). The other program with the same capability you can find it here
Hope this will answer your question.
model_=_l120__port_=_auto_selection__adjprog_ver_2017-08-25_12-49-37-gonwqssj54xei2lmigmvvzjk-4-0.png
Epson L120 Free Resetter
May 09, 2017 | Epson Computers & Internet
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson error 1004
Hi Thet, The link below is a Windows web site, Please read error 1004 and solution.... This will help you....CHEERS..
http://www.saetechnologies.com/epson-easy-photo-print-an-error-1004-has-occurred/
Apr 01, 2016 | Epson Office Equipment & Supplies
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
Scan without replacing print cartridges on Epson Stylus NX410?
You actually can scan documents when you dont have ink. Instead you will have to activate the scan function from the epson driver/program instead of pressing the scan button directly on the printer. I had the same problem and it took a while to figure out.
Feb 19, 2010 | Epson Office Equipment & Supplies
I have EPSON printer All-in-one type. It shows
try to check for printer spoolers if they are on follow these steps.
go to my computer,right click then go to manage,then go to services u will be able to see all the services runing on ur computer but in this case look for printer spooler service and start it.and make sure u put it to automatic.good luck.
Dec 17, 2009 | Epson Printer
Waste pad ink replace error in Epson Stylus Photo RX610
You can go to eserviceinfo.com, and see if you can download the service manual from there.
Aug 19, 2009 | Laser 3115cn All-In-One Printer
General error for epson stylus T10
green & red light blinking cant print epson t10
May 13, 2009 | Epson STYLUS R230 InkJet Photo Printer
Get an error message when trying to print test page
Please uninstall your printer then reboot the computer. Make sure your printer is switched off, then insert your printer installation disk and follow the instructions. Do not turn the printer on unntil asked to.
Please post a new comment if you need further assistance.
Dec 13, 2008 | Epson Stylus C60 InkJet Printer
130 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
