Question about Keurig Coffee Makers & Espresso Machines
My keurig b40 only puts out about 1-2 inches OF water IN standard coffee mug.
    Welcome Back:
    Visited the website for 2 consecutive days.
When that happens, the next cup you brew will overfill. I don't know why that happens.
Posted on Apr 17, 2015
BarrettDenCo
  • 1772 Answers
SOURCE: I have a Keurig B66, the reservoir water gets
Sorry to read about your issue.
Try this first....
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
  • 2039 Answers
SOURCE: The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 24, 2008
SOURCE: keurig b40
I dont think these machines are worth the money at all.
Posted on Aug 16, 2008
SOURCE: How do you drain a Keurig b40 coffee maker?
Empty the water reservoir and put back on the side of the Kurig. Put your hand in the reservoir and slide the disc that monitors the water level back toward the top and and hold in that position,the machine will think there is water. Then put a cup under the head and select a cup. The water will come out. You must hold the disc up inside the reservoir to continue to get the water out.
Posted on Jan 02, 2010
  • 5 Answers
SOURCE: Keurig water pump doesn't work
Just today we've found that at the first water intake (on my B60, that's where the water container plugs into the base) on the base is a little circle valve type thing. That's where the water gets sucked out of the tank. Shine a flashlight into that circle, and you'll see a screen type thing there. It's like the screen in your faucet when you unscrew the tip and there are little rocks and stuff in it? Same principle: there was cotton fibers and other assorted weird stuff clogging that screen. Used a toothpick or a needle and removed all the debris from the screen, and it now works perfectly!
Posted on Feb 18, 2010
My Keurig B40 has three different size cup sizes available, but it dispenses the same amount of water for the medium size cup and the large cup of coffee. It's barely been used so It doesn&am
I realize you think it does not need descaling to to it 'not being used much.'
However you may have hard water and I would think descaling is definitely worth a try. There might be scale built up on the water level probes in you machine.
Descaling Details are listed below:
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
(DO NOT USE A K-CUP)
Just press the BREW Button. Pour the contents of the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until "ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink.
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew cycles if you notice any residual taste.
Nov 20, 2014 | Keurig B40 Coffee Maker
How do i clean my Keurig?
Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Feb 24, 2013 | Keurig Elite B40 Coffee Maker
Keurig B40 problems
Clogged ports see page 18 Manual for assistance.
Feb 28, 2012 | Keurig Elite B40 Coffee Maker
While trying to run through the set up steps, both the Small Mug and Large Mug buttons stay blue rather than flashing. After switching to a dedicated outlet, the Small Mug button finally started flashing,...
I just bought a Keurig Elite B40 Coffee Maker myself, had same issue, Caledl Keurig support, problem solved in seconds. Seems an import step was left out of instructions. The step before the blue lights flash, RAISE THE SILVER HANDLE ALL THE WAY UP AND THEN CLOSE. According to Keurig this tells the brewer that a human is present and aware the brewer is running, a safety feature. Be sure you have a cup in place.
Mar 08, 2011 | Keurig Elite B40 Coffee Maker
Output from Keurig Elite B40 appears to be only 4oz for a cup and 8 oz for a mug, how can this be adjusted?
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
My Keurig b40 has stopped cycling water thru the cup holder portion. It only returns the heated water thru the small fitting back into the resevoir. This appears to be the only defect. Is there a valve...
Dec 22, 2010 | Keurig Elite B40 Coffee Maker
Keurig B40 model is not working after unplugging and replugging. The power light is blinking green. It does not respond to pushing any other buttons.
make sure you are not using a clear mug. i did and the sensor wouldn't pick up there was a mug there. so annoying!
Oct 31, 2010 | Keurig Elite B40 Coffee Maker
Keurig elite b40 cup lights don't flash. Both are illuminated solid.
Lift the handle to open the k-cup holder and then close it back up. The coffee mug lights should begin to blink for you.
Nov 27, 2009 | Keurig Elite B40 Coffee Maker
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
88 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
