Question about Epson Office Equipment & Supplies
How to fix error -1004 in epson L120
MY BRAND NEW EPSON PRINTER CANNOT PRINT. IT SAYS ERROR -1004. HOW COULD I FIX THIS.
  • 7 Answers
SOURCE: Epson 9800 Service Call Error 001002D
cleaning unit end of life
Posted on Dec 20, 2008
  • 4090 Answers
SOURCE: Epson 1400 Printing Orange colors Green
The problem can be two fold. Wrong cartridges, or blocked/damaged inkjet openings. Return it to the seller under warranty if its brand new. If it was fitted with non epson cartridges your warranty may be in question.
But I could almost guarantee the black qand the blue cartridges are faulty or their feed jets are
Posted on Jun 21, 2009
donpatie
  • 15 Answers
SOURCE: I have EPSON printer All-in-one type. It shows
try to check for printer spoolers if they are on follow these steps.
go to my computer,right click then go to manage,then go to services u will be able to see all the services runing on ur computer but in this case look for printer spooler service and start it.and make sure u put it to automatic.good luck.
Posted on Dec 17, 2009
cns assoc
  • 677 Answers
SOURCE: Epson Stylus printer is connected, but will not
Found this on the Web. If you find helpful, pls rate me.
Here is the link for all the discussions regarding this error.
http://discussions.apple.com/thread.jspa?threadID=2199441
Welcome to Apple Discussions
Go to: Apple > System Preferences > Print & Fax > Print and reselect your printer in the Default printer: box near the bottom of the panel. Then next in the same Print & Fax preference panel, select Open Print Queue: and Delete all the Jobs in the Status box and try printing something again.
reply
have no idea exactly what that error means, but now I suspect that when you "Trashed the EPSON folder in HD\Library\Printers\Epson" you trashed an important part of the OS X and not the installed Epson software.
If you have a backup Time Machine, a backup clone or that file is still in the trash you need to restore it "HD/Library/Printers/Epson/InkjetPrinters2 or whatever" back to the correct location, run Repair Permissions and hope that fixes it. If not then backup all your files, because it seems like you may have to completely reinstall the OS X....
Good Luck.....
Posted on Mar 05, 2010
  • 123 Answers
SOURCE: after print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Posted on Apr 15, 2010
Good day. i am using the ssc service utility to reset the waste inkpad counter for my epson l120 but error does always appear how could i fix this? please give me an exact solution to this? thanx..
You can't use SSC service to reset this printer EPROM.
The best solution to reset this printer by using Epson Adjustment program for L120 which you can get it from the other sites(for free). The other program with the same capability you can find it here
Hope this will answer your question.
model_=_l120__port_=_auto_selection__adjprog_ver_2017-08-25_12-49-37-gonwqssj54xei2lmigmvvzjk-4-0.png
Epson L120 Free Resetter
May 09, 2017 | Epson Computers & Internet
Epson error 1004
Hi Thet, The link below is a Windows web site, Please read error 1004 and solution.... This will help you....CHEERS..
http://www.saetechnologies.com/epson-easy-photo-print-an-error-1004-has-occurred/
Apr 01, 2016 | Epson Office Equipment & Supplies
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
How to resset my epson L120 i have my resseter but error code appear
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 04, 2015 | Epson Office Equipment & Supplies
WHY MY EPSON L120 CANNOT PRINT. THE MESSAGE ERROR -1004 POPS UP.
BRAND NeW return to place of purchase under warranty is it not
Apr 14, 2015 | Epson Office Equipment & Supplies
Dec 17, 2009 | Epson Printer
After print heads alignment its getting error 1004
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
Waste pad ink replace error in Epson Stylus Photo RX610
You can go to eserviceinfo.com, and see if you can download the service manual from there.
Aug 19, 2009 | Laser 3115cn All-In-One Printer
Jun 20, 2009 | Epson Stylus 1400 InkJet Photo Printer
Ink cartrige error(epson 9800)
I would try getting new EPSON brand cartridges for it and trying after that ...
Jan 19, 2009 | Epson Stylus Pro 9800 InkJet Printer
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
