Why after a loud bang did breaker trip on ac/heat unit. Wont run at all now
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
If its a heat pump and the compressor was running, there is a possibility that the compressor itself or something IN the compressor circuit shorted out and tripped the main breaker. It could also be something as simple as a shorted compressor run capacitor.
If its a forced air system with an electric air handler, resistance heat and central air conditioning....it could be just a shorted heating element that tripped a breaker OR it could have been a control circuit short that blew out the non-fused control transformer.
There are only about fifty scenarios that could have happened to cause the noise and to cause the systems failure....but these are the first few basics that could easily be investigated.
Posted on Apr 14, 2015
    Master:
  • 459 Answers
It seems the ac developed a dead short, exploded when shorted, then tripped the breaker. Electric test tools will be needed to locate the problem if not located by visual inspection of the electric wiring and components in the line voltage side.
  • 827 Answers
This is not something a home owner should try to troubleshoot, I have see too many owners get in trouble, best thing you can do is call a service man, it may cost a little more but you will get the unit back in service.
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
hello
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
I have 2 15000 BTU A/C units run to a double pole 20 amp each breaker. The breaker keeps over heating and one side will trip. Should i separate the units on their own breaker? The units cool and run fine...
That would work, if for no other reason, to isolate which one may be drawing too much/more amperage. Keep in mind as well, after a breaker trips too many times, it usually will get weak and trip at lower amperage. If all is same, ( wiring from AC units) and units are cleaned regularily and no other internal problems such as weak, bad, capacitors etc, they should both draw same or close to same. If possible that someone has a multimeter with amp draw clamp, that would confirm where trouble is.
Aug 09, 2011 | Dometic Rooftop RV Air Conditioner
Heat pump breaker tripped now no power to the unit at all
When AC unit trips the breaker it usually means one of four possiblities.
1) the AC unit is causing the breaker to trip, i.e. a shorted fan motor, compressor, or some other electrical component - in which case you will probably need to have a repairman look at it.
2) you've plugged the unit into a outlet that is connected to a breaker which is too small to handle the load the AC unit is putting on it.
3) a defective breaker (not likely but possible)
4) just a 'random' trip and if you reset the breaker it might work fine.
good luck!
May 03, 2010 | Haier Energy Star ESA3183 Air Conditioner
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
AC Runs for about 10 minute then trips breaker
is your breaker is ok or lose concation is good.if this both is good than cheek his overload.
Jul 20, 2009 | Dometic Rooftop RV Air Conditioner
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
