Question about Janome Memory Craft 9000 Computerized Sewing Machine
While sewing i switched to the ZIG ZAG Stitch and forgot to change the pressure foot. The neeedle hit the pressure foot and the fuse blew and the needle was knocked out of alignment.
Can you please tell me how to fix it. Thank you so much.
5 Suggested Answers
SOURCE:
SOURCE: no zig and cotton keeps breaking
Make sure you have a new sharp needle installed for both problems and sometimes you need a particular kind of needle for the fabric. Also some machines don't deal well with 100% cotton thread. For some reason it gets caught up in the machine somewhere and breaks. Gutterman and Metrosene make excellent although slightly more expensive threads. Coats and Clark thread is good too. They make an all cotton thread but it doesn't come in as many colors. If you have the old spools of cotton thread from Walmart, just use them for topstitching if you need the color. Other wise, use them for hand stitching or throw them away. One more thing that I can think of off hand, one of my machines does not like lining fabric. For some reason the thread breaks if I stitch really fast. If you have to use that thread, you may try sewing slowly. One more thing, when was the last time your machine was serviced? This can make a huge difference if it's been awhile and you use the machine a lot. Good luck. Hope any of this helps.
Posted on Apr 02, 2009
  • 980 Answers
SOURCE: MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
Posted on Jul 14, 2010
alicantecoli
  • 22484 Answers
SOURCE: I have a Memory Craft 8000. The computer screen
the mechanism is worn that makes the needle head move in a zig zag fashion ,need to be taken to a repair man to have the worn parts renewed
Posted on Oct 06, 2010
SOURCE: Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
Posted on Feb 03, 2015
Testimonial: "Thank you, Luong Trong Truong. You left me a message saying to remove the bobbin and leave the machine to run at least 10 - 15 minutes. Second time to do this was a charm and the machine is running smoothly. Whatever was stuck is now unstuck."
Model 930.Why is presser foot not lined up correctly?
Is your needle position centered? The round dial on the top right is a combination zig-zag stitch width selector and the center silver dial selects the needle position. If it is pointed at the #2, then the needle should be centered and something (probably the needle bar) has been knocked out of alignment on your machine (which would probably mean repair service).
Also, if the needle is hitting the presser foot, you probably have a straight stitch foot on your machine which requires the needle be centered. To do any decorative or zig-zag stitching, the presser foot needs to have a wide space for the needle to swing back and forth. The zig-zag foot is marked with a zero.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwiP-OL76L7JAhWG9x4KHZ-6AgsQFghDMAM&url=http%3A%2F%2Fberninainstitches.com%2Fpdfs%2FBernina_Presser_Feet_Guide.pdf&usg=AFQjCNFihfp9MHOUl_6HmXxRrC8t3N32TQ&cad=rja
Dec 03, 2015 | Bernina Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
Zig-zag settings
you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
Please look at page 40 of your manual for information.
As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
Trouble sewing lycra fabric using a zig zag stitch
You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
Cheers,
Embroidery Services
San Diego, CA
Sep 13, 2017 | Sewing Machines
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
What foot should I use for basic stitch or zig-zag stitch?
a all purpose foot or a zig zag foot will do both straight stitch & zig zag
Dec 16, 2010 | Singer Sewing Machines
I cannot get my tension adjusted correctly. I have lost my manual. Can you give me some help. Also, do I need a separate foot for the zig zag stitch.
usually a tension of 3 or 4 is good
only if the presser foot not is not made for zig zag--all the presser foot's that I've seen on new machines do straight stitch & zig zag,, if the opening in the foot is large then manually try a zig zag stitch to see
Nov 22, 2010 | Brother XR-65t Mechanical Sewing Machine
I need to adjust the needle so when I zig zag it will not hit the plastic. It works perfect on stright stitch.
You might have the zig zag set for z-z left or right-hand. Make sure you are choosing the zig zag centre stitch. Also check you are using the correct foot - it should be the A or B foot with the wide opening.
Apr 06, 2010 | Husqvarna Viking 1
Ingenuity-needle hits pressure foot when zigzag stitching
Reduce the width of the zig zag as a short term fix, but it seems that you either have the incorrect foot attached, or the ZZ width setting needs adjusting.
If, when the needle is set to be centred, is it actually slightly off-centre ?? You may do worse than have a service done, explaining the issue you face as well as a general go over.
As this was posted some time ago, I hope it has been resolved for you.
Mar 17, 2008 | Singer 7436 - INGENUITY
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
89 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
