Question about Bulova Clocks Miniature Clock B0425 Watch
I don't know how to take back off the mini Clock.... To change battery. Is anyone able to help? Thank you.
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
Unable to set the time in my sportline 3636
You can get instructions by going to http://www.sportline.com/category.php?cat=4
and locate your watch from the list and clicking on your model.
Now click on "more info" and you will find a tab marked "manual"
Oct 23, 2011 | Sportline Big Digit Watch
Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Sep 20, 2011 | Watches
I have an Elgin Westminster chime quartz wall clock (with pendulum). It uses a C-cell battery. It will not work at all. Please help if you can, since it has sentimental value to me. Don't know if...
I'm afraid you have to visit clock repair shop, as without close inspection it is not possible to say what's wrong with your clock.
May 18, 2011 | Watches
I just purchased a Heritage Mint Ltd Timepiece Quartz Regulator wall clock but it chimes two hours slower than the actual time. Need to know how to correct it. There is a red push button on the back of...
I have the same clock. Here's what I did to re-set it after changing batteries: After replacing batteries, use the turn dial to set the correct time. Press the RED button 6 times, wait for it to go through that series of chimes, then press the button again to set the time.
Example: Press RED button 6 times. Wait for it to chime. Press RED button the correct number of times for the hour to be set. For 5:00, press the button 5 times, etc.
I lost the directions to my clock, and I am posting this from memory and also just had to re-set mine and it works OK now.
Hope this helps!
Feb 07, 2011 | Watches
I have a Skyscan Atomic Clock - does anyone know how to set this clock for the right time zone and day, etc?
Hello.<br /> Thank you for contacting FixYa.<br /> You should be able to find instructions here!<br /> <a href="http://www.atomicclocksstore.com/skyscan-atomic-clock-model-81690-manual">http://www.atomicclocksstore.com/skyscan-atomic-clock-model-81690-manual</a><br /> Best regards.
Aug 25, 2010 | Watches
Airplane mini -dont know how to access battery
put a note on Facebook and suggestions - take it to a local jeweler, go to Wallmart where they have all kinds of batteries. So, I'll try the jeweler, and I have to find a wallmart - we are 14 miles from NYC - there must be one around here - so - not solved, but suggestions thanks anyway.adriana
Dec 20, 2009 | Timex Watches
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
Mauboussin Fouga Travel Clock
I would take it to a jeweller for repair.
Apr 15, 2017 | Mauboussin Men's 18K Gold Watch
Clock just stopped ticking
best option is to take it to your local wtch repair shop and pay their small proffessional fee to have it done by someone who knows what yhey are doing
Jul 18, 2007 | Peugeot 288BK Wrist Watch
Bulova Clocks Miniature Clock B0425 Watch Logo
42 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
