Question about Frigidaire Microwave Ovens
New microwave got condensation between glass panels. Got new door happened again. I think it's a design defect. How can I disassemble to clean as needed?
  • Frigidaire Master
  • 473 Answers
To be honest-- it's not worth the effort. Some doors do come apart and some are glued together. If the replacement door is only listed as a complete door it doesn't come apart. If it does come apart, it requires prying the plastic frame off the inner side of the door to get to the screws. The frames usually crack if you are not careful. Contact Frigidaire customer relations and explain the problem and see what they have to offer either as a repair or explanation.
Posted on Apr 15, 2015
Need to clean inside of the glass front panel. also want to get the handles of it and the grill white again not stained smokie colour
You might be able to get a manual for it on the manufacturers web site.
Have you looked into the price of a new door assembly? Given all the issues with the old door, it might be the best way to go. Plus, some doors simply can't be taken apart.
If you do decide to attempt to disassemble the door, you will need to have the microwave leakage level checked with a calibrated meter.
May 05, 2016 | Microwave Ovens
Brand new Model mircowave BMC253SS installed at the end of April. Condensation getting within the glass door this as already been replaced by your Baumatic Engineer yesterday and it is still happening....
Sounds like you need to call them back, they should warranty their work. Make them do it until ti is right. Make him show you it doesnt steam up before he leaves. OR Dont pay them and dont sign off that it is fixed.
Oct 14, 2017 | Microwave Ovens
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Glass continually shattering on combination neff oven
That's a huge gap.
You might ask their customer service people to authorize the replacement of the whole door or the glass and the inner door panel where the gap is.
If they won't help you, you could clean it thoroughly, then carefully caulk the gap with high temperature caulk.
Oct 09, 2009 | Bosch Microwave Ovens
Door handle broken away from microwave unit.
The door handle can easily be replaced. This is a common problem with microwave oven doors. You would think the manufacturer's would make them a bit more durable.
This is a very simple repair. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions about this repair, please let me know. I hope this helps you.
Jul 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace the handle. Can you give step by step help?
If you have questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | GE JVM1650 1000 Watts Microwave Oven
Condensation marks on microwave door
For most microwaves the process is pretty straightforward. You can open the door and you will see the screws that hold the outerinside panel on to the glass. After you remove those screws you will see the screws that hold the ouside cover to the door in place. Once you get that far you will see what is holding the glass in place. Keep in mind to replace the gaskets around the glass right and anything you take off to get to the glass itself. If you are getting condensation from range top cooking then the seal around the glass may need to be replaced. You really cannot hurt anything by taking it apart, but it needs to be put back together exactly the way you take it apart. Good luck and hope this helped.
Jan 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Seal replacement?
It sounds like your cooling fan has failed, or possibly the relay on the control board. This same relay also runs the turntable. Is the TT working?
It's critical for the cooling fan to work, or the magnetron can overheat, which will cause the thermostat to interrupt power until it cools backs down. Sounds like what happened to you.
If it gets too hot or gets hot too often, it can be ruined.
A failed fan can cause such overheating and a buildup of moisture as well.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 06, 2008 | Jenn-Air JMC7000 Microwave Oven
Condensation betwejn the front door glass
This would require disassembly of the door panels, which is not recommended unless really required.
You can download the installation guide to help you troubleshoot and correct your venting issues. That should be priority one.
It may be a clogged filter, a bird's nest in the outlet, etc. etc. Failure to vent can cause control panel and keypad trouble if it continues.
The manual / guide is found here: http://www.geappliances.com/service_and_support/literature/
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
249 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
