Question about Golf
Why want my 110 cc gocart engin start it wants to but want
  • Steve Harris
    Steve Harris Apr 14, 2015
    Hi micheal hill, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? You need to do some basic checks, is there gas and its primed. Is the choke open or closed. How does the spark plug look, does it need to be replaced. Is this engine old or new
  • 3,519 Answers
Hi Michael:
Here's my magic formula:
If there's spark at the plug, and fuel in the jug, it should run.
Check your spark plug, as in remove it, connect it to the wire, hold it against the head, and spin the motor over. Look for a hot blue spark. While you have the plug out, check for compression.
Check your fuel. Clean the carb, filter, and use fresh gas.
Odds are you should not be dealing with a timing problem so with any luck you'll be tearing up the track in no time.
Posted on Apr 14, 2015
  • micheal hill Apr 17, 2015
    Very helpful thanks .
  • Ted Maxwell Apr 17, 2015
    Feedback appreciated. Happy Day!
    Top Expert:
  • 10,875 Answers
Clean the carb
Posted on Apr 17, 2015
Why does my 97 Chrysler sebring run rough like a gocart?
If "rough like a gocart" means it rides stiff, and you feel all the bumps, that likely means that your shocks have gone bad, and perhaps your springs have sagged. It's possible that some of the joints in the suspension have seized up, too.
Jan 17, 2016 | Chrysler Cars & Trucks
Why wont my toyota carina 2 ltr. E start its always been so good but we had one hard frost and the next day it would not start with a jump but did start with a tow, the following day went to start it
Not familiar with your specific engine so some of this may not apply. Generally, sounds as if whatever acts as a choke on your engine has failed. Most common would be a coolant temp sensor, cold start injector, or very likely a moisture related issue, such as bad plug wires,cracked distributor cap, etc.
Dec 30, 2014 | Toyota Cars & Trucks
Perfomance data for peugeot engine code 1cw7p
what country sold? lots of 405s' world wide and diffr.
engine performance ?(on an engine stand?)
or the driving wheels to road performance.?
please say exactly what you want or post symptoms. or?
engine codes are very hard to find here. (USA)
ah, but are here.
http://www.scribd.com/doc/25423642/Peugeot-Engine-Code-Reference-List
XU5 or XU9 something are the engine, codes.
wiki: ,see bold , I added.
The 405 was available as a 4-door only. Four-cylinder petrol engines included 65, 92, 110, 125, and 160 hp (48, 69, 82, 93, and 119 kW) units. A 1.8-litre diesel engine, with or without a turbo (70 and 90 hp (52 and 67 kW)) was added to the range during 1988 as was the 5-door estate.
the 405 ended in USA in 1991.
The 405 range included three petrol engines and two diesel engines, all four-cylinder with no 6-cylinder option, in a variety of states of tune and specification. The range was tailored to suit different export markets. The 1.6-litre saloon featured a low drag co-efficient of Cd=0.29, with other models varying up to Cd=0.33. The 1.4-litre (1,360 cc) engine was fitted with a four-speed manual gearbox. It produced 70 hp (52 kW) at 5600 rpm. The 1.6-litre (1,580 cc) engine was fitted with a five-speed manual gearbox and produced 92 hp (69 kW) at 6000 rpm. The 1.9-litre (1,905 cc) engine was available with a five speed manual gearbox, with an option of an automatic in the lower powered version.
The 8-valve version of the engine was available in two levels of tune; 110 hp (82 kW) or 125 hp (93 kW). A 16-valve version was available with the Mi16 model and this produced 160 hp (120 kW) at 6500 rpm and could reach a top speed of 220 km/h.[4]
Jun 29, 2014 | 1989 Peugeot 405
My atv is 110 cc and wont start the celiode keeps makeing a clacking noise as if its jamed i changed it and same thing what cani do
kick start right,? is it kicking over fine with your normal compression like last time you rode it????
Sep 25, 2013 | Cycling
How to adjust a macCullouch 110 chain saw carb?
Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns each. This is a basic setting which should allow the engine to start and run. Check the fuel filter, air cleaner, and muffler for plugging. Start the engine and allow to warm up, then pull the throttle full on. Adjust H needle CW until the engine begins to speed up, but still 4-stroking. Proper final adjustment is when the engine 4-strokes when running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for smoother idle, yet still allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops moving, but the engine continues to run. Hope this helps!
Jun 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Funny sounds in engine
if the antifreeze is comming from the engine it could be a freeze plug or line blew open or loose
Jun 17, 2008 | 1991 Honda Accord
Golf Logo
624 people viewed this question
Top Golf Experts
Ronald Prier
Bill Boyd
Tom Chichester
Are you a Golf Expert? Answer questions, earn points and help others
