Question about Hardware & Accessories
I have an after market radio with a inner fairing antenna and cant pick up stations. what are my options for better reception cant do an external antenna has to be inner
SOURCE: AM radio reception
You are correct William, reception is not what it used to be for many reasons. Some corporate owners and local owners have spent much more maintaining FM facilities, and many have neglected the AM's. A good part of the AM signal is via the ground radials beneath each AM tower. In time these radials deteriorate, and with it the signal. Years ago stations licensed as daytime only shut down at night. Quite a few are now allowed to stay on with greatly reduced power, adding to the noise floor at night. You also have more AM licensees now than in the 60's. Unfortunately many of the really knowledgeable AM RF engineers have retired, or are close to doing so. AM directionals require a very experienced engineer. In addition we have many Part 15 radiators, that are devices that radiate a low level RF signal. Every home is full of them, thus more interference. We have power distribution systems that generate huge amounts of noise across the band too. Then there is the issue of manufacturers who have spent more on the FM receiver side of a radio as more migrated to FM. In the 60's, very few were FM listeners. Gone is sensitivity, selectivity and frequency response in the newer AM radios. There are a few exceptions, the CC Crane, and RCA SuperRadio, both sound good with great performance. By the way, the RCA WAS the GE SuperRadio. I also like to pick up some of the vintage radios on EBay and other sites, plus occasionally at yard sales. Unless you are in the country and don't have a house full of gadgets, DX listening can be difficult, but not impossible. Best of luck, capttomconroy@jetbroadband.com
Posted on Jul 19, 2008
  • 905 Answers
SOURCE: Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Posted on Mar 13, 2009
cjackHD
  • 71 Answers
SOURCE: AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Posted on Jun 22, 2009
  • 84 Answers
SOURCE: Radio in jeep cherokee will pick up few stations
Common problem... first, the antenna isn't connected directly to the radio... sometimes the junction points will crack and separate... second, sometimes the radios, radio tuner will go bad. if you have a Cherokee (not a Grand Cherokee) check you passenger side kick panel (location of a common antenna connection weak point) . Some genius placed a spring in the connection... just pull the spring out, reconnect and tape the connection together... Let me know if this helped at all... if the connections are all good, you will have to replace the radio... but, from what you described you wont have to...
Posted on Apr 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I am having very poor
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
See the manual, Page 10
Posted on Feb 04, 2011
Rear defrost problem
I am assuming that you mean that you are receiving interference on your radio. (Your description is very unclear.)
Window-mount antennas are notorious for bad reception and allowing interference. Your best course would be to mount an after-market external antenna on one of the fenders.
The other option would be to replace the stock Yaris radio (which is very poor quality) with a BETTER after-market radio.
Jul 19, 2014 | 2007 Toyota Yaris Sedan
97 mitsubishi bad radio reception
It sounds like you are just in a weak reception area. If you feel this is not the case first try replacing the entire antenna assembly, it would be the primary cause of this type of problem.
Jun 22, 2012 | 1997 Mitsubishi Mirage
AM reception
Jun 17, 2009 | Bose Wave Radio
Mar 13, 2009 | RCA 9V345T 9 in. Portable Television
Better fm reception
Is it just a single wire?
If so, purchase a cheap FM antena. It looks like a "T" when spread out (4' to 5'). That should help.
You can purchase an "amplified" antenna, but if your area reception is really bad (such as in a valley) the antenna would just amplify the noise as well. Look for web based radio in this case or if you have cable there are stations on it.
Jeff
Jan 11, 2008 | GPX HM3817DT Shelf System
Excessive static on AM stations. Waves in and out. Not so on car radio. Is there an antenna to eliminate this?
Turn on the radio and turn the AM/SW BAND switch to the AM position. MW appears in the display. Use the outer ‘fast’ tuning knob to find stations, fine tuning with the inner ‘slow’ knob
when needed.
• If there is interference from adjacent stations, place the BAND WIDTH control in the NARROW position. If there is no interference, leave it in the WIDE position.
• If there is excess background noise, turn on
the SW LPF switch, which may minimize the noise.
• If a station is so strong that audio distortion occurs, reduce the gain level with the AM/SW RF GAIN control knob by turning it counterclockwise.
• The telescopic antenna does not have to be extended for AM reception. The radio has an internal, directional, ferrite-bar antenna for AM reception.
• To optimize AM reception, swivel the radio until maximum signal strength is achieved.
All of that being said: It's very tough nowadays to receive AM in this 2008 electronic world. If your able install a longwire SW antenna outside, and have access to a good earth ground, you can boost the AM signals and beat the noise being generated all around you.
Jan 08, 2008 | Grundig S350 AM/FM/SW Radio
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Radio reception
the wire you use for the antenna is damage replace it or change the set to a other location.
Feb 19, 2007 | Brookstone Micro CD System with MP3 Shelf...
Hardware & Accessories Logo
455 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
