Question about Drills
How do you read those lights on the charger? - Drills
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Green means go.
Posted on Apr 14, 2015
Chargers green light goes off as soon as inserted in boards 3 pin connector and not charging. seems dead.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
Sep 19, 2016 | Blue Health & Beauty
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
Green and red light flashes on my panasonic impact driver charger
You didn't state which model charger or tools you have so I cannot find specifics on your charger. In all the chargers I've worked with and on, if both lights are flashing it usually means the battery is being read as defective and the charger won't charge it.
Jan 14, 2013 | Drills
I have a Model SS-51A-PE charger that will not charge an auto battery. Is this normal or is the charger mat functioning ? Don Robinson
If a battery is defective, it will not accept a charge and it is not the fault of the charger. When connected and switched on, with the clamps making solid contact, the amp meter should give you a reading, depending on the state of the battery. To do a quick test on the charger, try it across a headlamp bulb, The bulb should light and the amp meter should read about 5 amps.
May 11, 2011 | Schumacher & Fast Charge Starter Charger
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
I have a Pronto M91. When I push the joy stick the lights turn off and the first two red lights blink. I check all the connections and the wheelchair will not move. I would be thankful for any help.
You have low batteries and need charging if you been charging and still get the red lights then the batteries need to be replaced and have the charger checked for correct output. If you have a voltmeter you can check the charger by plugging the on-board charger into the wall set the voltmeter to 200 volts dc and plug the leads into the two outter holes of the charger port located under the front of the joystick. with the charger pugged in you should be reading 27+volts if you aren't getting any reading or the reading is lower than 25 volts then replace the charger or get an offboard charger and try charging the batteries via the joystick charger port Hope this helps
Mar 16, 2011 | Invacare Supply Group Invacare Pronto M91...
Charger is going to a green light just seconds after placing pn charge?
wnorman sounds like a charger problem but if you have a digital voltmeter you can check the battery voltage by setting the meter to 200 v dc and plugging the two leads of the meter into the two outter plug holes of the charger port located under the front of the joystick. Fully charged you should read 24-27 volts.
If you are reading less than 25 volts then you will have to replace the charger. I would ask around for anyone that has an off-board charger for you to borrow for a few hours charge with that charger and see if it makes a difference. If you still get a quick green light from the borrowed charger or when you checked with the voltmeter you didn't getting a reading then there is a connection problem. Hope this helps
Sep 25, 2010 | Electric Mobility Invacare Pronto M41...
No lights on charger when connected to wall socket or chair
flobo I assume that its the on-board charger and that it is the gray charger with one light. This charger light will only come on when the chair is fully charged. Now if you have left it plugged in all night and still have no light then I would think you have a bad charger. If you have a digital voltmeter you can check the battery voltage throught the external charger port under the joystick. Set it on 200 volts and insert each probe into the outter pin holes and you should be able to read the voltage. Without the charger plugged in you will be reading the total battery voltage 24-27 volts with the charger plugged in 27-30 volts also check the meter with the charger plugged it should show something above zero and gradually decrease as the batteries become fully charged. Hope this helps
Sep 04, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Drills Logo
65 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
