Question about Toro Garden
On my toro groundsmaster 223-d when i reverse it wont stop until i hit the gas . The adjustment part under the seat looks like the roller bering is broke what can i do
2 Suggested Answers
  • 107 Answers
SOURCE: Toro Groundsmaster 120 user manual
heres a link
https://lookup3.toro.com/request/request.cfm?lang=ca_en
you can download and print for free or purchase one from them....you will need your serial #
Posted on Apr 20, 2009
1999 toro groundsmaster 345 series gas engine will run with starter fluid but want stay running what is stopping it from staying running
You have no gas getting from the carb into the cylinder. Cleaning the carb will most likely fix the problem.
Jan 07, 2018 | Toro Garden
My toro groundsmaster stop running when you push on the pedal forward or reverse
Here's the link,select your model and you will find the answer.
toro
Sep 06, 2017 | Toro Garden
How to change drive belt toro groundsmaster 120
Loosen the idler pulley. Swap out the belt. Reattach the bolts. Check for clearance and tension.
Return to service.
Sep 17, 2015 | Toro Garden
Were is the safety switch for the pto on craftsman riding lawn mower
well there's three, there's the seat switch which can be found under the seat of course, there's the reverse switch which will not let you cut in reverse (just unplug it to be able to cut in reverse it you wanted but be careful of the little ones) which is usually near the gear shifter and then there's the break switch located under the mower (look along the break arm just follow the break under the mower and then you'll see a bracket that's flat and when the breaks pushed down the flat piece hit the button switch... why are you concerned? did it stop working here's a tip that most shops wont tell you just replace the main pto button first its cheap and 60% of the time its the main cause of the pto not working, but they wont hesitate to tell you that you need a 400.00 or so new pto. hope this helps
May 16, 2015 | Craftsman Garden
I need a diagram for toro deck 30753
Hi
I have located both the owners manual and a parts manual with breakdowns of all the components of your Toro 52" Groundsmaster mowing deck.
Both can be downloaded from Toro directly at the following link;
Toro 52" side discharge mower, Groundmaster 120 Toro Direct link.
I hope this helps you and if you have any further needs, please feel free to ask.
Jul 11, 2014 | Toro Garden
My Toro GTS 6.5 dies afetr 30 seconds and wont run
if you can see the carburetor, there is a small bowl that has a nut on the bottom side of it, remove this nut after stopping the fuel supply, inspect the nut and about half way up there will be a very tiny hole that you must clean out or unstop, this allows fuel to get to the main vent tube, and you can use a bread tie with the plastic removed; to unplug this hole or (jet). you may have to remove the air cleaner to see the float bowl. the nut is ususlly a 1/2 inch nut or 13MM. you can see a breakdown picture or diagram if you type in small engine, a carburetor repair and browse the pages a lot oftime i agree bit better than paying someone to unplug this hole for mechanics prices.
Jul 27, 2009 | Toro Garden
heres a link
Apr 20, 2009 | Toro Lawn Mower With Toro Power Tools
Groundsmaster 72
Have a toro groundmaster 72 that the spline went out in the power drive adaptor. the part is not avaible from toro.21-2260
Aug 30, 2008 | Garden
Garden Logo
74 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
