Question about Hobart Food Mixers
IAnthonyif you can help me my will hobart mixer A-200 first gear it's spinning but I can actually stop it from spinning with my hands
    Top Expert:
  • Hobart Master
  • 42,671 Answers
Get new gears or shaft as the drive is failed
Posted on Apr 14, 2015
bigg t
  • 640 Answers
SOURCE: Help? I need the Shop Manual for a Hobart A200 mixer. Thanks.
Ricardok45,I'm a hobart tech and can tell you nobody has ever bought hobart,they are a subsidary of illinois tool works.It's true hobart doesnt release any of their service manuals to the general public,however if you need guidence or parts i can help you.
Posted on Feb 24, 2009
ricardok45
  • 135 Answers
SOURCE: Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Posted on Feb 26, 2009
ricardok45
  • 135 Answers
SOURCE: HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
Posted on Mar 01, 2009
bigg t
  • 640 Answers
SOURCE: hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Posted on Mar 16, 2009
  • 81 Answers
SOURCE: Hobart D300 Mixer, Will not shift from 2nd to 1st
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Posted on Jul 25, 2009
I have a hobart a-200 mixer that had the brass drive gear go out. I rebuilt the transmission and used a parts breakdown to clean out and rebuilt the whole tranny. Now I have no 1st gear. Under a load...
Loosen the two planetary nuts, should be a thin nut and an acorn nut. With these loose make sure the large nut on top of the transmission is tight. Push the planetary all the way up on the shaft and turn the thin nut up until snug. Back the thin nut off 1/4 turn. Hold the thin nut in position and lock the acorn nut against it. The planetary must have a very small amount of up and down play.
May 20, 2010 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Motor worm gear hobat a200
Harry, if you're confident that you can take it apart and repair it yourself, then do the following. Go to www.hobartservice.com website. Register, and when you've been admitted to the site find the discontinued products section on the left hand side of the page, click on it, then select the Food Machines Group, then select Mixers. Make sure that your ML# is covered by the document.Select the file numbered A-200 Parts List F-6728. pdf. Look for the ML#. Once you've selected the document, go to page #9, there you'll find the exploded drawings for the A 200 transmission parts. If you look at the whole document (15 pages), you should be able to see what needs to be taken apart to get at the worm gear.
If you're not sure you can do this...Then don't do it. But if you do, check all bearings, springs and gears for excessive wear and replace as necessary. Hobart techs do this stuff every day. For someone who has not done this kind of rebuilding before, it can be a long and expensive learning curve. Good luck. If you find that this solution has been helpfull to you, please rate it. ricardok45
Jan 04, 2009 | Hobart A200 Stand Mixer
Hobart a-200 3rd gear lock-up issue
do you have a spauge cutch first gear or a diving key locking type? sheck shifting collar for being rounded off on the gear and the collar they get rouned off and won't lock gear in.
Nov 28, 2008 | Hobart A200 Stand Mixer
Hobart A-200 First Gear is Having Trouble
If the mixers are older the dive key shaft,spring or key are broken,if they are newer the key is sheared.Also check the nuts near the beater shaft and make sure there not too tight.
Nov 13, 2008 | Hobart A200 Stand Mixer
A 200 T grease leak & gear noise
The o-ring on the attachment hub gear is wirn causing the leak.If the mixer is old it wouldnt hurt to change the grease.
Sep 28, 2008 | Hobart A200 Stand Mixer
Hobart A-200
goto this site http://www.hobartcorp.com/default.aspx. you will find a parts list/view. before ordering any parts i would call your local hobart branch because the part numbers have changed.make sure you have the ml number or spec number found on the data plate before hand so youll get the right part numbers.any questions let me know,i repair alot of these mixers im a hobart service tech.
Nov 12, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
147 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
