Question about Samsung SGH-E900 Cellular Phone
How to put a message ring in my phone
Wen i put my phone into my computer and then i compose a message ring tone i cannot save into the menu of my ringtone how can i get a message ringtone
Approach ur service provider he will assist u
Posted on Feb 01, 2008
Not able to put the Nokia E5 phone in Vibration Mode
When you get to your phone's setting, select profiles. Amongst the list of profiles, determine which of them you want to use to activate your vibrate mode.
When you have done that, scroll to that profile, select 'options', then select 'personalise'.
In the personalise sub-menu, you are allowed to set the features of that mode to your desire.
In the ringing tone, select no tone, in the ringing volume, reduce the volume to zero. When you are asked if you want to set the ringing volume to the maximum, select yes/ok.
In the vibrate option, select yes/vibrate.
In the message tone, select no tone.
For other sounds and tones, select no tone.
When you are done, REMEMBER TO SAVE IT.
Then go back and activate that profile.
It is advisable that the profile you use for this though, is your 'silent' profile.
Hope that was helpful?
Have a wonderful day.
Jun 20, 2011 | Nokia E5 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Nokia N72 Cellular Phone
If i cant put ringtones on my nokia 1661 then how come i the ringtone catergory it has four empty slots?
You cannot put ringtone on you nokia 1661 because there is no feature for you to do that on your phone.
The four empty slots are for ringtones you compose from your phones composer.
To create ringtones from your phones,
Go to your phones 'menu',
Select 'Extra',
Select 'composer',
A page with music notes will come up, after composing your polyphonic tone, you can store it in one of the four empty slots.
Take care
Jun 23, 2010 | Nokia 1661 Cell Phone
Ring tone volume issue
you can reset your phone setting to original just save your number in simcard and save your important data then put any different simcard and goto menu setting and phone setting then last option factory reset your phone will restart then try ring tons
Mar 31, 2010 | Nokia 6600 slide Cellular Phone
I cant set a ring tone for a text message.
Go to Menu, Setting, Sound Profile, select profile, I prefer Normal, go to the drop down menu (you should see Call), select Message, go to Message Alert Type and choose Melody, go to Message Alert Tone and touch Tones (bottom right corner) select the tone of your preference, press Add and Save... have a Blessed day!
Oct 08, 2009 | Samsung SGH-A877 Impression Cell Phone
My ringtone goes beep
  1. Push Menu
  2. Choose Settings (Wrench icon)
  3. Then Ring Styles
  4. Choose the second option (Ends in the word "Details")
  5. Change the ringer for messages to be different then calls
Aug 23, 2009 | Motorola Mobility RAZR V3
Composing of new Ringtones
you can get new ring tones via sms or you can compose it by yourself
first press menu,goto extrasin thatpress composer in that you can edit the tones which you already had or you can press by yourself
Sep 13, 2008 | Nokia 1110 Cellular Phone
Ring Tones
Try This:
Open the message. Than hit the menus button. Find save items and click it. It should than ask you to save what? select file and save the ring tone to your phone.
To send a ringtone.
Open Sounds, find the one you want to send, click menu, than send in message.
Dec 10, 2007 | Motorola Mobility RAZR V3
Samsung SGH-E900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
