Question about Pool & Spa
Pool leaks almost all the way around the seam at the bottom. what do i do?
Its not even a year old. Its been stored inside over the winter. its only second summer I want to use it.
    Top Expert:
  • 42,218 Answers
Check the warranty period for the pool liner
if in warranty period ask for a replacement
. if not there are special plastic glues available from a pool shop that will do the job or take the liner to a upholstery or plastic awning manufacturer and have it welded again
Posted on Apr 14, 2015
  • 1,631 Answers
Is it an Intex?
Pool Vinyl Patch once you find origin of leak.
or try contacting manufacturer.
How to fix a hole in a swimming pool liner
  • Get some food coloring...
    • Squeeze bottle works best
    • Or pool leak detection Dye
  • get some good goggles...
  • get in the pool, start at one specific area...
  • and take a deep breath...
  • Now follow all the seams 1st, squeeze some dye in a suspected area and watch. If the dye gets sucked in, there's a leak! If it just puddles and hangs around, keep checking somewhere else.
  • Once a lead IS found, vinyl liner pool patch! Can even be used under water.
Amazon com Vinyl liner pool patch Patio Lawn Garden
Leakmaster Pre Filled Dye Tester For Finding Pool Spa Leaks
Oct 15, 2014 | GLI Pool Liner 050012rdlucub52 12 Round,...
Tip
////////////Detecting The Hole In A Leaking Pool Liner////////////
Pool liner has a hole in it....you keep adding water far too many times a week running up your water bills far to high....you call a pool guy and he recommends a "Diver" to call, when you call the diver you fall through the floor when he tells you the initial cost no matter whether he finds the leak or not.
This is what i have learned from the experts....had a pool diver come over and all he did was 'Nothing"...he charged me $400.00 took out and resealed my lights...broke my brick stones around the pool in various places due to his removal of the air tanks, talked a good line of balogna, took my check and left....left me $400.00 lighter in my wallet and no better off then I was before concerning my pool liner leak, he even told me after he came back to find it three times again that the leak was all in my mind and that the dropping of the water level was due to evaporation... this is all good fior someone who is new to a pool...but I have had this inground pool for 10 years prior to him telling me he usually always finds the leaks....he did not and tried to cover his inadequecies with a ration of bull stories...I was adding at least 2-3 hundred gallons of water everyday whether it was hot out or cold out, and this only started happening after about 10 years of owning the pool, in this case it didnot pay to have someone dive the pool because when you can see a real strong discoloration in your liner and the water level starts to drop all of a sudden every other day to at least 1/2-1.0 inches it is time to replace the liner.
If you have a newer then 8-10 year old liner by all means have it tested before you replace it, a cheap and inexpensive way to do this is to start at some point... I would first buy a $4.00 rubber plug to plug up the bottom drain....see if the water level drops...if it does problem is someplace else if it stops dropping the prblem is in the drain lines and that can be an expensive fix for an inground pool short of just leaving it plugged and never using the bottom drain feature again.
If the drain plugging doesn't fix the problem try blocking off the lines with plugs one at a time until you find the level stops dropping indicating which line is culprit, including the skimmers and please be sure you leave the filter off while doing these tests.
If none of the above finds the leaks get in the pool and being very still discharge a small puff of red food coloring under water around the light lense frames...trying to see if it gets sucked into a leaking area, also around the stair case if so equipped doing the same thing with the dye around the seams etc.
You may even find the filter is leaking at a joint causing the leak, or like i once found.... little under ground critters ate my skimmer lines... they punched pin holes into the rubber buried lines with there teeth...they were small moles, nocturnal like rodents that burrow under ground causing havoc on anything that is buried beneath the surface....I found this problem easily...the ground all of a sudden became wet and damp and eventually started to pool up with water for no apparnt reason...when I dug into the water pool I found a little gusher of water coming from the lines, these critters ate into the lines...had to cut them and couple them with a sleeve for the fix.
on Sep 17, 2010 | Plumbing
Center pipe was cracked when we took it out to replace the sand what would cause this plus there was sand under the bottom cover
Typically, the cracking of internal filter tank components is due to freezing temperatures over the Winter season. You should always COMPLETELY drain all water from your filter and store it inside during the winter.
Another reason is over chlorination of your pool water and/or adding chemicals directly to your water thru the wall skimmer.
Aug 27, 2013 | Hayward SAND FILTER, PRO SERIES
My 14' pool is leaking from the bottom slowly. 1" per 26hrs. I can not find a hole. No water on the sides of the pool. It is leaking out from under it. How do I find the hole. I have patched holes...
Using goggles I inspect the bottom and looking at each individual speck on the bottom. Sometimes what looks like debris is actually a hole though it seems it would take a good size hole to leak that much. Check the seam by gently trying to spread it.
Jun 14, 2011 | Intex Easy Set Pool 15x36
I noticed my pool was leaking air. I opened the upper ring blow up valve and there is hole inside of it. Can this be repaired? I would hate to get rid of my pool just because the air valve has a hole...
Take a 12 X 12 piece of plastic wrap, wet the pool ring, slide the plastic sheet along until you see the air bubble appear, mark leak with marker pen. Use repair patch. I swear this is better than soapy water!
Jun 19, 2010 | Intex Easy Set Pool 15x36
The bottom portion of my 48Ft DE filter has a crack. Can it be fixed or replaced?
You should be able to get a replacement tank bottom from a pool supply store or even online. I would not suggest trying to fix it since it can run at a fairly high pressure if it gets dirty. You can probably seal the leak but the crack is not structurally sound and poses a danger to anyone around it when at operating pressure.
Nov 05, 2009 | Hayward EC-40 DE Pool Filter with pump
Leaking on LXIH dishwasher that is level
No. The water level is controlled by two probes inside the back RH corner of the tank. Level the unit with the smallest tilt backwards.
I would closely look at the wash (and rinse arms if equipped). Make sure there is no missing plugs (depends on how old unit is if plugs are used), and that there is no debris inside the wash arm. Debris will cause the water to spray off-line and hit the door seam directly.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Leaky pump
There are rubber gaskets inside that get old and need to be replaced. Thats probably why it's leaking........Thank You For Using FixYa.Com! : )
Jun 17, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
After the winter I set up the pool soft pool 549x132cm again but this time the blue and grey in and outlets keep leaking there is no normal way I can stop this maybe you have an advice? regards henri
If its the outlets going into the pool, it sounds like you are missing a insert , my pool has hose inserts which stop the leaking. Hope this help. Pool stores have the differnt size inserts
May 06, 2009 | Intex Above Ground Pool 530 gal/hr Water...
Unable to get water clear last season could it be faulty pump
Although the chips inside the pump could decrease the efficiency i doubt that this is why you were unable to get the pool clear. What type of filter do you have, how old is the media inside it, and was the water just cloudy, or did you have algae problems?
Apr 06, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Pool & Spa Logo
82 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
