Question about Cooktops
My Ariston cooktop ignition seems to work ok other than it trips the power after it ignites. What part may cause this?
    Loyalty:
    Visited the website for 30 consecutive days.
  • 372 Answers
Could be a temperature sensor thinking it did not light, or could be a breaker tripping to a bad igniter.
Posted on Apr 14, 2015
We cleaned to cooktop and now the igniters don't work. the ciruit breaker won't reset and continues to trip
You are short circuiting the cooktop. Make sure no metal is touching the igniters. Check everything again, making sure everything is in place correctly. Also make sure it is fully dry.
Jan 20, 2016 | GE 36 in. JGP628 Gas Cooktop
Downdraft fan nor igniters work Electric tested and ok - what else could it be?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 11, 2010 | GE 30 in. Profile JGP989 Gas Cooktop
None of the four burners will ignite when the gas is turned on. The electric igniters don't spark. The gas comes out and can be ignited with a separate butane lighter. I believe the electric power is on to...
Check that electric power closely. A boil over and attempted re-start or water (or other liquid) leaked / spilled into an igniter switch can trip your GFI outlet. Sometimes the outlet the cooktop is plugged into is fed from a GFI recepticle further " up stream " so you may have to look around to find a GFI which has tripped.
Feb 08, 2010 | Cooktops
Kitchenaid gas cooktop will not ignite.
check 1st i have a power or in plug the unit,if ok the power, nid to replace ther ignition coil but is expensive,use macth temporary if u use ur cooktop
tnx gerbee
Jun 27, 2009 | KitchenAid Architect KGCP484KSS Gas...
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
Ignitors are not working
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Mar 18, 2008 | Smeg 23 in. SE64 Gas Cooktop
Igniters will not work
did the water fall on the spark module do you hear a faint click ,igniters dont go bad if they get wet if you say theres power going to the cooktop then you might have a bad spark module.
Dec 24, 2007 | Kenmore 36 in. 33384 / 33385 / 33389 Gas...
Cooktops Logo
103 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
