Question about Pool & Spa
We dont think the filter is running correctly and none of the lights work they only did for the first 2 weeks its our 4th week owning the spa we need help please
    Loyalty:
    Visited the website for 30 consecutive days.
  • 374 Answers
They might be on a timer and only work at certain hours of the day, if the time is set wrong............
Posted on Apr 14, 2015
  • 1,631 Answers
Be more specific please...
  • Is there power to spa?
  • when you say lights... Do you mean the "mood setting' lights,
  • when you push the button marked 'Light', those lights don't work?
  • or are you saying the Control Panel no longer lights up?
    • Or backlight illumination?
or... The control panel itself is not showing anything? Does it work? If you push a button, does anything happen?
What is the make and Model of your new spa?
and... What makes you ask the question about filtration? What is going on now that is different, than when you first got it?
    Top Expert:
  • Pool & Spa Master
  • 50,084 Answers
Filters don't run they just filter what ever is being pump through them
the fluid is supplied bay a pump and that pump has to have power
check house fuse,
if the motor is humming when switched on the replace the start / run capacitor
if the light went out at the same time have an accredited electrician check out the wiring and connections
Cant put into gear. Errors anti pollution sytem failure. Low oil pressure
change mechanics --or bring back and have them fix correctly when they did the engine work doesnt sound like was done correctly and now you may have a bigger problem
Aug 08, 2016 | 2007 Peugeot 207 CC
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
We bought an intex sand filter last week and it runs strong for a little whole and the loses suction why is a this happening?
needs to be backwashed small filters dont have alot of filtering capacity keep backwashing until what is in your water is gone also super shock pool
Jul 04, 2014 | Pool & Spa
I just purchased a used Jewel series spa a couple of weeks ago. Got it hooked up and everything was running fine. Now is seems the pump will not stop running. It is up to temp and keeps running at low
Low speed is your circulation function, all filtration, heating etc is done by the low speed. Check how many filter cycles and duration the spa is set to.
Is the temperature on the control panel correct? Verify it is with in a 3-4 degrees of a floating thermometer.
Jul 26, 2012 | Pool & Spa
We have a 15' by 48 " pool with an Intex saltwater chlorinator.About two weeks ago the low salt light started flashing .We ended up adding way too much salt (160 lbs)because the low salt light kept...
First of all green water can arrise from a lot of different situation.
Low chlorine is one of them coupled with the crappy filter that comes with the intex pools it does not filter enough.
Start with getting your salt level to 3000ppm
any lower than 2700 and you will not generate enough chlorine and any higher than 3500 and you could go cloudy or trigger high salt alarms
you need to get the salt test kit that reads in #'s not color the color ones has to much of a variance
once your salt is at 3000 clean your cell then filter filter filter
I run my filter 24/7 if it is not generating chlorine I am filtering.
Clean your cartridge every few days
I have had the same 2 cartridges for this being my 4th season and have never been green or replaced the filters.
Also I reccomend a non foaming algecide
Just follow directions on bottle
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I had a transmission flush done 2 weeks ago. 1 week later my \low traction light came on whenever I accelerated from a stop. Now 1 more week later my ABS and TSC lights are on. There is a little shudder as...
First, Iam not a fan of flushing a trans. Owned a trans shop years ago.
You may have caused some solenoid issues, with the clutch material and cooler sediment.
Work on the ABS,TSC issues. Wheel Speed Sensors may be going and just a coincidence, a couple weeks later.
Make sure the fluid is correct for your vehicle and at the correct level.
I pray you didn't go to one of the Quick Lube Franchises.
Aug 03, 2010 | 1999 Pontiac Montana
Chlorine generator not working(brand new)
Super shock your pool ... take it to around 20 ppm CL using liquid or powdered CL. Brush your pool daily for several days ... run your filter at least 16 hours a day ... 24/7 would be better. Maintain 5 ppm CL and brush weekly after you get the algae under control.
Jul 23, 2010 | Intex Automatic Salt Water System for ...
High speed setting on pump won't work.
might be the starter capacitor or run capacitor
Jul 14, 2009 | Pool & Spa
Pool & Spa Logo
61 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
