Question about Toto Home
We have a Toto and every time we flush makes an awful sound like a foghorn.It fills up okay.How do we fix it?Sound or vibrating seems to come from the blue oval piece, below where the number18 is
arealplumber
  • 33 Answers
SOURCE: Toto GMax Flushing System drips
What you are experiencing is a flapper valve problem. Since I don't know what model you have I will give you a link to the generic GMax unit. Here is the parts breakdown for a GMax
Toto GMax
I would suspect you need part #7 on this diagram a flapper valve. Take the old one with you since different colors ones are used on different models. You should go to the Toto site to locate a dealer first. You can find their site here:
Toto USA
Hope this helps and please remember to rate this!
Posted on Dec 09, 2008
SOURCE: Delay on tank fill after flush. Toto Drake bowl ada elongatred
I am not a plumber but stumbled across the solution on my own. While watching the float during the flush cycle, it was obvious that it was very slow in moving downward along with the water level in the tank. The problem was that the small opening in the float chamber was partially clogged. Using just my fingers, I reached under the float chamber and cleaned off any debris that was blocking the opening underneath the float chamber. Put the float back on, and instantly the problem was solved. The tank fill started immediately after I flushed.
Posted on Jun 30, 2009
hansola
  • 279 Answers
SOURCE: my dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Posted on Nov 08, 2009
bearsfan7538
  • 119 Answers
SOURCE: need diagram of toto toilet tank inside have
You need to replace the fill valve
Posted on Nov 15, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
My Jacuzzi toilet is making a foghorn sound after flushing. I read in FAQ to close the fill valve slightly but I don't know how to do this. Please help.
IF there is a valve on the water line in the toilet close this off it should turn clockwise to slow down the pressure
Jul 12, 2017 | Jacuzzi Home
When I flush my toilet I get a Foghorn sound for a few seconds what causes this ?
sounds like its the water rushing in to refill the tank try closing the fill valve just slightly to slow the water down
Apr 27, 2015 | Home
The toilet makes a pulsating sound after flushing
If this noise your hearing is water related and I talking inlet water filling the tank then the ballcock needs rebuilt or replaced.
Now if every toilet in the house is doing the same sounds then we are into a different scenario.
Feb 02, 2011 | Toto Carlyle 1-piece Elongated Bowl Toilet
My Kohler toilet is about 5 years old and is making this awful whistling sound after being flushed. What part needs to be replaced so I can make it quiet again!?
The valve that fills the toilet is making that sound... it is filling up with dirt and the water is struggling to get through the smaller hole...
heatman101
Sep 03, 2010 | Home
Hello, we have a dual flush toto and since installation we've had a problem with the water filling up after a flush. every single time i have to take the cover off and twist the flush valve (the part on...
check the water supply tube.remove and check to see if any blockage is present.either remove completely and blow through it,or just remove top of tube and inspect it.this has happened to me various time's.possible solution.
Apr 16, 2010 | Toto Aquia II Dual Flush Toilet
Toto toilet with gmax flushing system blue top
Jun 20, 2009 | Toto Drake ADA Compliant Toilet with...
I have a toto toilet. After flushing it is taking a very long time to fill up.
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Mar 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
Flush
it sounds to me as though its the ballvalve not shutting off properly & when it does shut off the noise you hear is a water hammer, and my guessing is you have a water meter with a back flow prevention valve fitted so when the ballvalve shuts off the pressure exerted on the valve cant go anywhere due to the back flow unit so the noise is the water reverberating through loose pipe-work, annoying but not damaging
Dec 12, 2008 | Toto Toilets ST784S 12 Sedona Beige...
Home Logo
347 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
