Question about HP DesignJet 110 Plus InkJet Printer
Black printhead out of line. Prints staggered lines
Ok my plotter was printing fading black lines, I messed with the printhead and screwed it up it started leaking ink so I knew it was shot. I ordered a new printhead and when it came in I could never get it installed where it wouldn't blink like I had a bad printhead. I ended up taking plotter somewhat apart the cover and tried to clean out service tray. I'm not sure if I screwed something up when I did this. I ordered another printhead thinking maybe the first one I ordered was bad. When the second one came in I installed it and the blinking printhead went way. So after all of that my main problem was the first printhead that I ordered was bad. I put the plotter back together and it is working now but in one direction I am getting slightly staggered lines. The yellow ink cartridge is showing empty even though it is not but it is old. Right now when i run the printhead alignment it only gets halfway through then fails every time. I am wondering if I can get it yo run all the west through the printhead alignment if that will fix it or if it's something else. Help please
  • HP Master
  • 5,631 Answers
A long story, short answer: probably you have a problem in your printer. You should take it to a repair service and hoe repait kit is available for this model.
Posted on Apr 14, 2015
Printhead for office hero 6.1
I replaced black ink cartridge and now no matter how many times I clean/calibrate only the black ink messes up. I tried other brand new cartridges and same thing. Even a calibrate shows missed lines or faded lines
Jul 07, 2012 | Kodak Office Hero 6.1 All-in-One WiFi...
When it prints black cant hardly see,if i print a color and black and white you cant see black print
Common error for Printhead that some colors on your printout are missing.
1. Clean printhead twice press menu button> select clean printhead> select basic/deep clean
2. Test Print Press photo and copy button at the same time for atleast 10 sec. or until it prints
3. Reseat the printhead Simple remove the inkcartridges and the printhead close the printer access door without the printhead. Open the printer access door put the printhead and the inkcartridges back. Then close the printer access door. DO TEST PRINT if still missing colors
4. Replace printhead Contact Kodak AiO support line at 1 800 421 6699
Nov 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink prints half a page then fades out. Sometimes does not print black at all. I have replaced the black ink cartridge twice and ran "clean printheads" many times. Still will not work
HI since you tried replacing the cartridges and cleaning the printhead, try the steps below.
1.Print a Demo Page.
a.Press the Menu button of the printer.
b.Use the down arrow key and select Print Demo Sheet.
c.Press OK button.
If demo page doesnt have black ink or faded prints,the printhead on your printer require replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Test page prints fine, but nothing else does
You need a new printhead, QY6-0049-000 around $40.00. Your printhead has worn out or plugged nozzles and cleaning won't help.
Jul 09, 2009 | Canon i860 InkJet Photo Printer
I have a hp8250 and about every 6th line is faded
you need to change the printheads but first take a cotton swab dip it in water and then clean the printheads copper contacts and the place the printheads sit inside the printer .place the printheads back inside and now try to print if u still face the issue replace the printheads and then check whether it still gives a problem if it does call in to hp and they will replace the printer.
1800-474-6836
Jun 18, 2009 | HP Photosmart 8250 InkJet Printer
Printing every other line of text
The black is the first to burn out on a printhead, you just need a new printhead.
Jun 11, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Wont print black just gray! new HP!
Ensure first that is not a setting problem, check that the printer is not in Economy or Fast print mode, and try to print with a different resolution settings.
If printer prints fading black on all conditions and this is not a settings problem, then the printhead is defective.
In that case have the printer replaced.
Mar 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Prints faded
Hello mvjv,
To solve the faded prints you need to clean the printhead twice by going to the software and click the "?" mark icon on the upper right corner of the software window and then under General Links select Maintenance then choose Clean Printhead - do it at least thrice to unclog the printhead system. Then try making prints... If still cannot solve call Kodak Technical Support.
I hope I have been some of help.
Nov 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Wont print in black.
hi,
check the ink level of the color cartridges also. because to print in black it will use some color also.
if everything is ok try this
> unplug the usb cable from the printer
> click on "start-->control panel--> printers and faxes".
> select all the printer icons which is related to your priter and delete it.
> once that is done, plug the usb cable back to the printer.
> wait for few minutes while it installs the driver automatically.
> if done, try printing in black from varius applications like notepad, wordpad, ms word etc.
> if o go, you may have to service the unit as you have already tried with 3 different black cartridges.
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 3210 Printer
HP DesignJet 110 Plus InkJet Printer Logo
96 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
