Coolant fan doesn't come on unless I run air conditioner.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
"Coolant Fan" is not necessarily a common term used to refer to any particular fan in a standard HVAC system. Are you referring to the "Indoor Fan" that circulates the air within the living space???? OR are you referring to the "Outdoor Fan" or "Condensor Fan" that circulates the air across the outdoor coil ??
If its the indoor fan on an air handler that's not running unless its in A/C mode, it will be a faulty heating circuit fan relay on the main control board.
If its the outdoor fan and its a heat pump system the outdoor fan stops during the defrost mode so there is a slight possibility the system defrost board is faulty and stuck in defrost.
A little more information may help obtain a more specific answer.
Posted on Apr 14, 2015
  • 415 Answers
SOURCE: RUUD UBHA-14 J11SFJA air handler. The fan (blower) doesn?t runs
Absolutely, however, you want to properly diagnose the reason why the fan is not running. It could be a less expensive part than the fan motor itself.
First, check to see if you have the proper voltage going to the motor. I believe your motor requires 240volts ac. If you do not have 240 volts, you have a control problem.......either the thermostat is failing to close R & G or your blower relay may have failed to close the contacts necessary for your fan to operate.
If you have the voltage, then you want try spinning the blower wheel with your hand. Does it spin freely? Is the motor warm/hot? If so, turn everything off for an hour or so. As soon as your energize it, try spinning the motor with your hand again.....if it spins freely with no resistance and then starts running by itself, the problem is the run capacitor (approx $20.00 depending on where you purchase it from). If there is resistance when you try to spin it, the problem is most likely with the bearings and you will need to replace the motor.......if you have to replace the motor, go ahead and replace the capacitor also, making sure it is properly "matched" with your new motor.
I hope you find this to be very helpful to you, moving forward. :-)
Posted on Mar 28, 2010
bobicehouse
  • 1524 Answers
SOURCE: the fan runs on the air conditioner but the
Try replacing the compressor capacitor.
Posted on Apr 09, 2010
  • 311 Answers
SOURCE: air conditioner fan run,but compressor makes popping soun
Go buy a new a/c unit as the compressor is locked up in all probability and if the sealed system has no warranty left.
Posted on May 28, 2010
wise_jf
  • 66 Answers
SOURCE: have haier outdoor air conditioner compresser
It probably needs a capacitor. If you have a voltmeter that will check microfarad, you can check it. You did not say what size unit you have. But the fan is likely a 5 MFD It will say on the old one. The old one probably has 3 terminals on the top and is a cylinder. The top will be marked C, Herm and fan. You can buy a 5 mfd capacitor for about 10 bucks. Run a wire from the C side of the old capacitor to one side of the new one. Remove wires from the fan side of the old one and put on the other side of the new one. Be sure you secure the new one in a place where it cannot short out. Most of the time this can be accomplished with a wire strap.
As always be sure to disconnect the power before servicing. Also disconnect the power on the furnace. This will prevent any damage from occurring to the inside unit.
Posted on Jul 12, 2010
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Radiator electric fan not working
May be a clogged radiator, air in the coolant line, low coolant? fan relays?
Mar 30, 2014 | Pontiac Firebird Cars & Trucks
Peugeot 207 fan assembly not working
sound like engine coolant temperature sensor faulty also coolant level too low.
May 27, 2013 | Cars & Trucks
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
While running the air conditioner the Thermostat goes hot, when I turn the air conditioner off it goes back down. The low coolant light came on but the coolant is full. What else could it be?
To start with, you are talking about the temp gauge. The thermostat is in the engine.
The coolant system could be low or have air pockets and still look full.
First thing I would check is the cooling fan, then the coolant level.
Jun 30, 2012 | 1999 Ford Taurus
Danby DB98-26786A window air conditioner will start up and blow cold air..frost forms on the tubes..after a few minutes the frost disappears and the compressor shuts off .. the fan still blows; but no...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 23, 2011 | Danby Heating & Cooling
I have a 2007 Chrysler 300 2.7 that keeps overheating and backing up into the resivor. I have changed out the thermostat and change out the coolant sensor. I've checked all relays, good. The radiator...
You missed the cheapest and most likely part of all. Change your thermostat. It may be sticking. Incidentally, coolant is suppose to not only back up into your reservoir on occasion, it is suppose to take from it as well. This is normal.
Jun 06, 2011 | 2007 Chrysler 300 AWD Sedan
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
1993 pontiac bonneville electric cooling fans relay location
Hi, check.........I need to know which fuse runs the cooling... on this forum thread. Its not a fuse if the fan turns but could be fan relay. Unplug the coolant temp sensor lovated just below the thermostat houing and see if the fans come on. If they do, it might be the coolant sensor that is bad.
Apr 13, 2010 | 1993 Pontiac Bonneville
The radiator fan will not turn on unless the air conditioner is on
try to see the connection if still good..replace it if not...and see the fuse if still working
Oct 24, 2009 | 1993 Saturn SL2
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
