Question about Xerox Office Equipment & Supplies
How can restore the id and pass default ware service center xerox phaser of 3020 ?
Change the default password and forget
  • 26 Answers
SOURCE: Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Posted on Apr 27, 2009
antiochpc
  • 1314 Answers
SOURCE: xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Posted on Jun 23, 2009
  • 2072 Answers
SOURCE: How do I reset a Xerox Phaser 4500 Centreware
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Posted on Mar 03, 2010
SOURCE: Default admin password for Xerox Phaser 8550DX
Default admin password is 1111
Posted on May 03, 2010
  • 1684 Answers
SOURCE: XEROX Phaser 6100 service manual
We have the Phaser 6100 Service manual available at:
http://www.ccl-la.com/catalog/
Posted on Jul 21, 2010
HOW DO I REMOVE PASS WORD ON 3210-3220 XEROX WORK CENTRE IN FAX SET-UP?
You can contact a Xerox service center and see if they can provide the default password. In most of the WorkCenter MFP's the previous owner would seldom change the default. But if they did, the Xerox service tech can probably tell you how to reset it once you provide the serial number and proof of ownership.
Dec 24, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
Driver
http://xpdrivers.com/printer/hewlett-packard/laserjet/3020/_5_960.cfm
Oct 08, 2014 | Xerox Phaser Office Equipment & Supplies
Usb is not detecting xerox phaser 7400
My copier is not able to operate because of Dept ID and password. So, can you suggest ways to remove the Dept ID and Password?
Jul 17, 2013 | Xerox Phaser 7400DN Laser Printer
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
Mar 03, 2010 | Xerox Phaser 4500 Printer
Feb 19, 2009 | Xerox Phaser 6120/YN Laser Printer
Pass code forget
If you have changed your password from the default one then nothing ca be done.You will have to give this to service center.Here are the default pass which you can try:
1234,0000,12345,00000
Feb 10, 2009 | Sony Ericsson K770i Purple 3G Camera...
How to reset a forgotten admin password on a xerox 4150
PRESS # AND ACCSES SIMULTANIUS FOR 3 SECONDS
PASSWORD 1934
Oct 01, 2008 | Xerox Office Equipment & Supplies
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
