Question about GE Washing Machines
My ge heavy duty large capacity washer stopped during wash and smelt burning rubber... Is it worth fixing?
    Top Expert:
  • GE Master
  • 44,293 Answers
Certainly-- the burning rubber is probably a loose or broken drive belt underneath
however the ultimate decision can be made after a service person has inspected it and quoted on repairs and parts ( if still available)
Posted on Apr 14, 2015
5 Suggested Answers
Destinova
  • 46 Answers
SOURCE: Kenmore Elite Heavy Duty King Size Capacity Top Load Washer Won't Spin/Agitata
I am sorry to say that you WILL need a tech to come out and service this unit.  From what you are telling me it is either a dead short in the motor, OR one of the conntections got wet and cause a short.  BUT I would put my money on the motor, since this is a direct drive unit.  Sorry
Posted on May 26, 2008
landsend
  • 1066 Answers
SOURCE: Squeaky washer in spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
How good are you and your tools?
Posted on Apr 01, 2009
jumptrout51
  • 3361 Answers
SOURCE: My GE Washer , which is a 9 cycle, 3 spd
You need to check the lid switch for continuity. A bad lid switch will prevent this machine from agitating or spinning.
Posted on Oct 05, 2009
pappapumpdaf
  • 635 Answers
SOURCE: MACHINE STOPPED - BURNING SMELL COMING FROM WASHER
The burning smell is from your coupling and when this breaks the rubber spins across the plastic face of the opposite coupling. Your washer will not wash or spin until this is replaced. fortunately these are cheap and easy to replace. Refer to my step by step instructions to replace yours.
Here is the guide:
http://www.fixya.com/support/r4355933-washing_machine_repair_direct_drive
Posted on Mar 24, 2010
Old ge heavy duty extra large capacity washer g157
You have the wrong category, post question to Washing Machines Category. A bit more info would help, like what the problem is.
Jul 04, 2013 | Computers & Internet
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
I have a Roper Heavy Duty Large capacity washer # RAB5232EW. during every spin cycle it is unbalanced and knocks like it will jump out of the wash room. Please Help!
when empty turn it upside down it should have three springs holding the washing machine to the frame
one mabe missing if that not the prob try leveling the load and make sure the leveling leggs are all
toutching the floor good luck
Oct 17, 2011 | Roper Washing Machines
GE Top loader, Heavy Duty, large capacity washer does not advance cycles but stays in one cycle. I have to manually change cycles.
Depending on the exact model number it sounds like you are dealing with a bad timer or bad clock on the timer. There are contact points inside the timer and they burn out. Sometimes the clock goes bad It has plastic gears inside and is non serviceable. The only thing you can do is replace the timer or call a local repair technitian to make sure.
Oct 26, 2010 | GE Washing Machines
I have a hotpoint , heavy duty large capacity washer and it runs but after each cycle , you have to manualy turn the knob to next cycle for it to work ,it is an older washer but does it just need the knob...
Some of the old washers have a delay between each cycle that seems long but less than 2 minutes. If this is not the cause you will need to order a new timer not the knob. Sorry if its very old it may not be worth it.
Aug 16, 2010 | Hotpoint Washing Machines
Load was to heavy and I smelt burnt rubber now no spin
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning “rubber” smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Please check this diagram for the part number F28(drive belt)--
Please post back for any further assistance.
Thanks
Daniel
Jul 24, 2010 | Frigidaire FWS833A Top Load Washer
Mar 27, 2009 | GE WBSR3140DW Top Load Washer
Whirlpool gold UIltimate care heavy duty super capacity washer
Well you can check the capacitor with a meter for farads, but it sounds like you have a clutch and/ or gearcase failure causing the motor to overheat. The second thing to do is unplug the washer and check the timer. I would right after the agitation to inspect for heat and burnt connections.
Oct 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
