How do I fix frequent duplexer paper jams? - Office Equipment & Supplies
  • 5,631 Answers
Probably some part is worn out. Have may bad quality plastic parts! Specify your printer/copier whatever maybe reparation kit is still available
Posted on Apr 14, 2015
Kyocera 2100dn says paper jam in duplex unit but there is no jam paper.how can i fix?
the duplex unit is on top of paper cassette remove the cassette pull down the green lever inside the machine and remove the paper jam you cant see the paper otherwise
Feb 08, 2017 | Kyocera FS-2100DN Laser Printer - FS2100DN
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
How to remove paper jam from duplex unit
No issues i share a informative links please visit and read it.
Read more help... How to fix printer paper jam andHP Printer Support
Thanks,
Aug 26, 2014 | Ricoh Aficio SP C820DN Laser Printer
How can I prevent paper jam 0207 on canon 2230
Although paper jams occur because of dirty pickup rollers I have found that jams occur frequently because of solenoids in the paper feed mechanism (the assembly that the paper trays fit into). There are two of them and over time the damping foam on the levers get sticky causing the lever to operate late which causes the jam. As a fix I remove the damping foam and put insulation tape on the lever making sure the solenoid works by using a 12v bench psu before reassembling. You will need service manual because Paper Feed mechanism removal is a little complex.
Paper feed problems in Canon Laser Jet Printers are caused by these solenoids mainly in Duplex mode. P3005dn's etc.
Hope this helps solve yr problem.
Jul 29, 2014 | Canon Office Equipment & Supplies
How can I stop paper jams when using duplex printing?
1. Replace "Roller top out put bin" (RL1-0527-000CN)
2. Clean duplexer unit & chk the rollers in size change assembly(RM1-1318-000CN)
Apr 29, 2014 | HP LaserJet 1320tn Printer
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
My school's computer "Lexmark E323" has a paper jam and nobody knows how to fix it
hi!!!!try to open the duplexer at the back of your printer and see if there's a paper stock in the duplexer who cause a paper jam to your printer.
May 01, 2009 | Lexmark E323 Laser Printer
k24674
jasbo
jasbo
