Unit will not start it is just like it has a dead battery
    Master:
  • 409 Answers
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If this doesn't fix your problem when you may want to call a professional.
West Palm Beach Air Conditioning
Posted on Apr 15, 2015
How to use a compact jump start system
The Jump Start replaces another vehicle when jump starting. Make sure unit is fully charged. If you need a jump start because of a dead battery in your car, connect Red lead to + battery post on your dead battery and Black lead form jump start to - battery post on dead battery. Turn unit on and start vehicle.
Sep 01, 2014 | Power Center Jumpstart 11-411
3300CE charging problems
The battery on my unit is dead. What could be the cause? Possible causes for a dead battery on battery operated units: 1. Battery has lost its ability to hold a charge
2. Charging system on unit has failed (battery cables, alternator, or alternator control board)
3. Stuck key on the display is causing a constant draw from the battery.
The battery on my unit is dead What could be the cause
Jan 14, 2014 | Stairmaster Exercise & Fitness
2005 Dodge Truck 2500 / Brake lights flashing while truck turned off / dead battery
i don't know why but dodge trucks back feed threw the trailer lights and leave light on
Aug 31, 2012 | 2005 Dodge Ram 2500 Truck
Smart2200RMXL2U shows no sign of life after storage
These units, while hot swappable, will NOT start with dead batteries connected.
You will have to replace the batteries to confirm if the unit is still usable. Sealed Lead Acid Batteries do have a shelf life when a charge is not applied and will fail after several months of sitting around.
If your unit was working fine before it was put in storage, I definitely would consider just replacing the batteries. It is possible that the batteries are connected loosely, you can try opening the unit up to double check all the connections but if it has been sitting for more than a couple months, I would definitely consider the batteries dead.
You can find replacement batteries here http://www.refurbups.com/Tripplite-SMART2200RMXL2U-Batteries
Apr 02, 2010 | Tripp Lite Smart Pro UPS System
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
2000 Jetta Radio is dead after a dead battery jump start
Some German cars have anti-theft device inside to make it useless to steal...check at the dealership to see if jumping the battery will activate this(the car thinks its being stolen) .
Apr 29, 2009 | 2000 Volkswagen Jetta TDI
I have a car jump starter unit that was left and went dead flat. Now it will not take a charge pluging in the charger?
Unfortunately, a Jump Starting Unit which no longer takes a charge usually means the internal batteries had gone bad. On some charging units, the replacement batteries are available through the manufacturer, but more times than not, it's less expensive to replace the Jump Starting Unit.
Nov 09, 2008 | Energizer Rechargable Battery with Charger
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
